1. AC Question's Avatar
    Hey guys, I'm just wondering if anyone knows gow much it would cost to fix my Samsung Galaxy S7 Edges back camera screen?
    06-20-2016 04:35 AM
  2. H3aTeRzz's Avatar
    Hi
    Can you tell us what happened? If its a manufacturer defect, then its covered under warranty. The camera itself is cheap, less than 10.00 on ebay. Now, the repair is a different story, but "ususally" pretty easy to fix, if you wanted to try it on your own (if not warrantied). Buy the part on ebay, and watch the video below. If this scares you too badly to do, then bring it in to a local repair...."shouldn't" be any more than about 75.00, if you bring in the camera with you, that you purchased off ebay.
    Hope this helps:
    s7 edge rear camera | eBay
    Chris
    06-20-2016 09:39 AM
  1. Samsung Galaxy S7 Edge - Game launcher and Game tools not working
    By loomis9301 in forum Samsung Galaxy S7 edge
    Last Post: 02-17-2017, 05:14 PM
  2. samsung note 5 fast charging does not work always
    Last Post: 06-20-2016, 07:39 AM
  3. "getting massage MediaServer failed. Restart Camera.
    Last Post: 06-20-2016, 07:38 AM
  4. Replies: 1
    Last Post: 06-20-2016, 04:17 AM
  5. getting massage MediaServer failed. Camera needs restart.
    Last Post: 06-20-2016, 04:12 AM
