1. AC Question's Avatar
    If i press volume up it would uust go back from its orginal place
    And if i press down it it goes back to its orginal place also from where i pressed the volume down button and my phone heats up every time i use the volume buttons
    06-20-2016 08:04 AM
  2. the tall guy's Avatar
    Hi, if the device heats up when you are trying to turn the phones volume up and down I would definitely recommend you take it back to where you bought it from and ask for a new one as this isn't normal.
    06-20-2016 09:54 AM
  1. Setting up scheduled group messages are not delivering, what can I do?
    By AC Question in forum General News & Discussion
    Last Post: 06-20-2016, 08:49 AM
  2. Replies: 1
    Last Post: 06-20-2016, 08:12 AM
  3. Replies: 1
    Last Post: 06-20-2016, 07:19 AM
  4. My S6 is going on mute automatically
    Last Post: 06-20-2016, 07:18 AM
  5. Why is my switch/lock screen not working at all?
    By AC Question in forum Samsung Galaxy J Series
    Last Post: 06-20-2016, 07:16 AM
