1. cowboyzx6's Avatar
    Whenever I put the phone on the charger, the phone never goes into Always on Display mode after the inactivity period. The phone dims a bit, but then just stays on whatever screen I had it on and never switches over to the Clock/Calendar I have setup.
    When not on the charger, it does correctly go to Clock/Calendar dislplay. I have tried both Wireless charger and plugging directly into USB and no go either way.
    Any idea how to fix this?
    06-22-2016 09:25 AM
  2. zkyevolved's Avatar
    Just out of curiosity, do you have developer options enabled? Because as I recall there is an option in there to prevent the screen from turning off while plugged in.
    06-22-2016 09:33 AM
  3. cowboyzx6's Avatar
    That was it dude!
    I actually did not have developer options turned on. But when I did turn on developer options, I then noticed that the screen option always stay on while charging was enabled. Disabled it and all good now.
    06-23-2016 05:43 AM
  4. Qukol's Avatar
    At me such was when the network was always connected. The phone could not break the connection and went to sleep.
    09-28-2016 08:37 AM
  1. Why am I unable to access my total space on my S6?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 06-22-2016, 03:01 PM
  2. Replies: 1
    Last Post: 06-22-2016, 01:34 PM
  3. Replies: 1
    Last Post: 06-22-2016, 09:23 AM
  4. Replies: 0
    Last Post: 06-22-2016, 09:19 AM
  5. Why does it say to use genuine battery?
    Last Post: 06-22-2016, 08:57 AM
