1. AC Question's Avatar
    I have searched the internet high and low. Here is my issue. Whether at home or at work, if the WiFi connection is interrupted for a second and it looses connection, my Bluetooth also gets disabled and whatever music/movie I'm listening to plays through the speakers on phone. How do I stop this?
    06-23-2016 08:06 AM
  2. CrixusofCapua's Avatar
    Degener84u likes this.
    06-23-2016 08:13 AM
  3. the tall guy's Avatar
    Hi, that's a strange bug to have - what phone do you have? is the device rooted and have you installed any recent software update?
    06-23-2016 08:30 AM
  4. CrixusofCapua's Avatar
    This was my question. sorry thought I was logged in
    06-23-2016 09:15 AM
  5. CrixusofCapua's Avatar
    I have S7 edge. Not rooted. yes I installed latest update. It's been happening for a while now.
    06-23-2016 09:16 AM
  6. CrixusofCapua's Avatar
    I tried different bluetooth headphones and happens to all of them. They work on my fiancees S7 edge
    06-23-2016 09:17 AM
  7. CrixusofCapua's Avatar
    Does anybody know what is causing this? It still shows its connected via bluetooth in bluetooth settings but no sound will come through. Only way to get it to connect again is by turning the headphones off and then back on.
    06-23-2016 09:46 AM
  8. htc fan89's Avatar
    Think you have to send it in for repair, I had a similar problem with my note 5.
    06-23-2016 01:06 PM
  9. H3aTeRzz's Avatar
    Hi
    If a wipe of the cache partition doesn't help (in recovery) then you should try a factory reset before bringing in for repair, it might help. Be sure to back up your device before the full reset.
    Chris
    06-23-2016 01:13 PM
  10. paridge's Avatar
    AT&T did a firmware update in May that addressed this issue, I think. Not sure whether other carriers have done so.
    06-24-2016 12:33 AM
  11. anon(19981)'s Avatar
    I have posted the same issue that your having since the last June security update. It does not lose bt connection if I remember to turn WiFi off prior to leaving a WiF area.
    06-24-2016 03:47 AM
  1. Replies: 1
    Last Post: 07-14-2016, 08:16 AM
  2. My LG G Stylo is locked out for 72
    By lbeauty1965 in forum More LG Phones
    Last Post: 06-23-2016, 10:54 AM
  3. Why wont my htc desire turn on past the boot screen?
    Last Post: 06-23-2016, 08:34 AM
  4. Why my moto e shutting down simply?
    Last Post: 06-23-2016, 07:20 AM
  5. When Gionee marathon m5 will get Marshmallow update
    Last Post: 06-23-2016, 06:43 AM
