Missed call counter does not reset - S7 Edge. How can I get it to reset?
foooooo
Okay, i recieved 3 missed calls today, and the thing i keep figuring out is why does my s6 edge , before this S7 edge, reset the missed call counter once i pressed the phone icon and my S7 edge doesn't
it keeps one counting missed calls even if i clear it, its now like 9 missed calls and counting
phone details :
samsung galaxy s7 edge
stock android, just got a few games, mostly i just logged in most of my apps
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
165,519
4,659
113
Welcome to Android Central! If you don't mind setting your homescreens back up, you could go to the App Manager, select TouchWiz Home, and Clear Cache/Clear Data. When you go back to the homescreen, they'll be blank, and you'll have to set them up again. This is, of course, not an ideal option if you have to do it regularly, but if it's only every now and then, it's not too much of a hassle.
andrew_ackley
956
Re: Missed call counter does not reset - S7 Edge
phone details :
Usually it's just a bug and a restart of the device will fix it.
