1. Abby Normal's Avatar
    So my phone just told me it has installed the apps edge.....
    Anyone know what that is .. I'm not clicking on anything until I can find out what it is....
    A google search just keep son bringing up links about the edge phone......
    06-25-2016 03:44 PM
  2. PJRed2008's Avatar
    It's a Samsung app for using the Edge features. Its discussed at length in the phone users manual.
    06-25-2016 03:50 PM
  3. pjwk81's Avatar
    Swipe in from the right about ⅔ of the way up. If that doesn't work then check the settings section for Edge screen and turn Edge panels on.
    06-25-2016 04:01 PM
  4. tracypagedotnet's Avatar
    You should be able to see the edge "icon" once it's activated. The default setting is not large, like you see here, but notice the edge "icon" on the right side
    Edit: It's washed out by the white background of the forum, but on the right side you see the 1 & 2? Just to the right of them you can see the white tab that looks like a cut out or glitch, but it's just the same color as the forum
    06-25-2016 04:28 PM
  5. Abby Normal's Avatar
    Got it
    Thanks guys...
    06-25-2016 05:08 PM
  6. cwbcpa's Avatar
    I dont wanr to get off track and it sounds like you got your answer but I just had to tell you that your name and picture are awesome. That's one of my favorite movies of all time. My brothers and I have quoted that movie for as long as I can remember.
    06-25-2016 09:16 PM
  7. pjwk81's Avatar
    Got it
    Thanks guys...
    Best thing to do now is turn it off, as it's pretty much useless
    06-26-2016 02:30 AM
  8. lycan666's Avatar
    Wohhh what theme are you using , screen looks super
    06-26-2016 03:48 PM
  9. tracypagedotnet's Avatar
    It's an app called Kustom Live Wallpaper, the theme I'm using is Arisonite. I do have the pro-version and this is probably a paid theme too
    https://play.google.com/store/apps/d...allpaper&hl=en
    https://play.google.com/store/apps/d...risonite&hl=en
    06-26-2016 09:41 PM
  1. File Replicator App
    Last Post: 06-25-2016, 03:28 PM
  2. My games start to dim out on my galaxy s7 edge?
    Last Post: 06-25-2016, 03:07 PM
  3. how can I get the ipolis mobile app on my bb9930 .
    Last Post: 06-25-2016, 02:49 PM
  4. How do I get my widget drawer back tab back on my app
    Last Post: 06-25-2016, 02:41 PM
  5. Replies: 0
    Last Post: 06-25-2016, 02:03 PM
