moving from Windows Phone to Samsung - Contacts not shown in 'Phone', help please...
zlx
11
Hi @ll
I've just moved from Windows Phone to Samsung Galaxy S7 Edge. All my contacts are in live.com account. The contacts are now shown in 'Contacts' on my Samsung, but not in my 'Phone' App. It somehow did not syncronized the two apps.
Did the same on my wifes phone where it worked perfectly. What am I doing wrong? How can get my 'Contacts' into the contact-section of my phone-app?
Any help much appreciated! Thanks
zlx
11
Have you tried checking the contacts to display settings?
Thanks for your reply. Yes, it's set on 'All Contacts' in 'Contacts to display'
It seems that Android can not import the phone numbers etc (Names and e-mail addresses are imported correctly)
Have to enter all contacts into my gmail account's contacts manually I guess :(
btw. I hate outlook com now!
pjwk81
754
Is there a way to export the contacts so you can import them into your Google Contacts on a PC? I did something similar before doing icloud contacts to Google for someone.
Allen Brandt
113
Try creating a new account under settings /accounts: Microsoft Exchange (you might need to create a one time password for this), then check the options to allow contacts to sync. It works perfectly (I also sync the calendar this way)
zlx
11
Thanks for your replies! I did add my live.com account as 'outlook account', synced everything and cleaned up duplicate contacts. Now I'm 95% happy with my new samsung :) thanks again for your replies, I really appreciate it!
