1. shankey7292's Avatar
    I am using Samsung Galaxy S7 edge. The phone was working perfectly until I used a tampered glass on it. After using tempered glass the touch sensitivity of the phone around the edges has decreased. I am afraid that if I won't use tempered glass the screen will gat scratches. Which tempered glass should I use so that touch sensitivity is not affected? Is there any problem if I don't use a tempered glass at all? Please give solution to my problem!
    06-27-2016 03:36 PM
  2. ThrottleJohnny's Avatar
    Not to mention, one that doesn't dull the great screen.
    06-27-2016 04:16 PM
  3. dpham00's Avatar
    A plastic screen protector will help against scratches.
    06-27-2016 04:29 PM
  1. Remote of Google TV is locked
    By Mido26 in forum Google TV
    Last Post: 06-28-2016, 12:45 AM
  2. Why is my battery drawning when is charging
    Last Post: 06-27-2016, 05:27 PM
  3. Is there any tempered glass which wont decrease touch sensitivity
    By shankey7292 in forum Samsung Galaxy S7 edge
    Last Post: 06-27-2016, 04:29 PM
  4. Why is my phone performing so horribly?
    By Max Valor in forum Ask a Question
    Last Post: 06-27-2016, 03:34 PM
  5. Replies: 0
    Last Post: 06-27-2016, 02:59 PM
