1. Avvakening's Avatar
    Does anyone know if such a thing exists? I'm basically looking for something the width and depth of the phone that extends maybe half an inch from the bottom of the phone and plugs in to the 3.5 mm jack providing much better front-facing audio. I'd basically want to use it to replace the speaker that comes inside the phone.
    After a quick look I haven't found anything, but I could just be using the wrong keywords. If anyone knows of such a device, I'd really appreciate a link to it.
    06-28-2016 12:34 AM
  2. chanchan05's Avatar
    Basically you want a case with speakers built in? Why not just bring one of those smaller keychain bluetooth speakers?
    06-28-2016 04:11 AM
  3. Avvakening's Avatar
    Because that's far from seamless. A case would work just fine, but with how terribly the S7 Edge handles drops with glass literally on every side of it it'd need to double as a protective case.
    Speaking of cases, I'd have one on mine anyways so I doubt even if what I want existed that it'd actually fit without some kind of 3.5 mm jack extender of a perfect length. I'll probably have to go with what you suggested either way or just stick with what the phone has and use my headphones when I have them with me.
    06-28-2016 04:36 AM
  1. Replies: 2
    Last Post: 05-16-2017, 06:05 PM
  2. Replies: 2
    Last Post: 08-20-2016, 09:28 PM
  3. Why isn't my LG G4 turning on?
    By AC Question in forum LG G4
    Last Post: 06-28-2016, 12:51 AM
  4. Samsung Galaxy S7 Edge - Add-on Speaker?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 06-28-2016, 12:48 AM
  5. How can I add a recipient, to a Verizon conversation?
    By AC Question in forum Samsung Galaxy Core Prime
    Last Post: 06-27-2016, 11:27 PM
