1. AC Question's Avatar
    I've been noticing that for the past few days, my battery has been draining WAY too fast. After 2 min off the charger, it's at 98% and just goes downhill from there. In the settings->battery, the Android System is using 75%!! It was at 12% or so ever since I got it and is now draining my battery. How can I fix this?
    06-28-2016 10:04 AM
  2. belodion's Avatar
    Try first a Power Off and Restart.
    Tell us what that does.
    06-28-2016 10:22 AM
  3. Farah Sabbagh's Avatar
    I tried and the 75% held. Android System 75%, Android OS 6%, Screen 6%, Cell Standby 2%.
    06-28-2016 10:50 AM
  4. belodion's Avatar
    Yes, but I mean, does it make a difference after say a day's use? If, after charging to 100%, you still see high Android OS battery usage after a day's use, it will not have made a difference, and other tactics will have to be considered. But it's always worth trying the simplest fixes first.
    Also, welcome as a new member.
    06-28-2016 02:06 PM
  5. Farah Sabbagh's Avatar
    Thank you No, it's no better after the day. I've checked the battery usage regularly every few hours and it's been between 50%-75%, even with all of the apps closed. I didn't think much about it up until 2 days ago. I was finding that just having it with me, it would drain from 100% to 65% in the course of an hour or two.
    06-28-2016 02:13 PM
  1. why doesn't snapchat filter work on my galaxy s5 phone
    Last Post: 08-31-2016, 04:00 AM
  2. Replies: 1
    Last Post: 06-28-2016, 10:14 PM
  3. New to the Edge and a question
    By Nodnerb in forum Samsung Galaxy S7 edge
    Last Post: 06-28-2016, 01:52 PM
  4. Why does my S7 get hot when it's charging?
    By Jerry Verb in forum Samsung Galaxy S7
    Last Post: 06-28-2016, 11:07 AM
  5. How do I get online when I'm not at home?
    By AC Question in forum Misc. Android Tablets
    Last Post: 06-28-2016, 09:48 AM
