1. wdt258's Avatar
    I have added 4 or 5 stocks to my edge feed but it will only show the first stock and not the following ones. It doesnt scroll across like a ticker, it used to but don't know why it doesn't now.. please help n thanks for your time!
    PS: it says updated quotes delayed and when i try to scroll over it wont move the first stocks and give a blue circle on the left side of it
    06-29-2016 04:49 PM
  1. After OS update, password has been changed to PIN
    Last Post: 06-29-2016, 08:35 PM
  2. Helium App not finding location of data
    By jrandallg in forum Android Apps
    Last Post: 06-29-2016, 05:13 PM
  3. how to delete every part and install android clean?
    Last Post: 06-29-2016, 05:07 PM
  4. How do you unsync a phone that is connected to mine.
    Last Post: 06-29-2016, 05:05 PM
  5. Replies: 0
    Last Post: 06-29-2016, 03:57 PM
