1. Baladeva's Avatar
    Hi, there is a problem with my s7 edge... I can't see videos recorded with the phone in my smart tv samsung... it began after two or three last software updates... anybody can help my?
    06-29-2016 03:57 PM
  2. SpookDroid's Avatar
    Do you get any error from either the TV or the phone? I'm assuming you're trying to 'mirror' the phone onto your TV, or are you trying to play them in a different way?
    06-29-2016 04:15 PM
  3. Baladeva's Avatar
    Thanks!! The message of code error appear in TV, but it happened just with videos recorded with the s7edge, if I play videos mp4 from S7 but recorded with another devices or downloaded so there is no problem, I'm using quick connect to mirror my s7 videos in tv.
    greetings to you!
    07-02-2016 07:42 AM
  4. Alanhd's Avatar
    Whats your record settings on the phone? have you tried record at different sizes.
    Also have you checked to see if there's a Firmware update for your TV.
    Ive just checked on my TV and I was running an old software version.
    Baladeva likes this.
    07-02-2016 08:51 AM
  5. Baladeva's Avatar
    Thanks! Yes! I tried recording in differents sizes and also updating my TV.. but nothings happened... the situation is that this error happened with last automatic software updates. Even i was in touch with technical personal of samsung and they test my phone trough an app called "smart tutor for samsung" and they told me all is android responsability... and then they advice me put in touch with this site...
    07-03-2016 07:40 AM
  6. Alanhd's Avatar
    Sounds like Samsung are playing pass the buck.
    Have you got everything backed up. It's a bit extreme but I would be tempted to reset the phone if it was mine. Will probably save you time in the long run.
    You could try clear the system cache first, that sometimes clears up errors.
    07-03-2016 08:55 AM
  7. Baladeva's Avatar
    And how I can do it?
    07-05-2016 08:37 AM
  8. Alanhd's Avatar
    How to clear the system cache on the Galaxy S7:
    1.Turn the Galaxy S7 or Galaxy S7 Edge off
    2.Press and hold the Volume Up, Power and Home buttons at the same time until the Android logo shows up
    3.Then let go of the Power button and continue to hold the other buttons
    4.Use the volume buttons to scroll down to highlight Wipe Cache Partition
    5.Press the Power button
    6.Scroll down to Yes and press the Power button
    7.Scroll to Reboot System Now and press Power
    8.Your Galaxy S7 will reboot with a cleared system cache
    07-05-2016 11:31 AM
  9. SpookDroid's Avatar
    I'm not sure what could be going on, I just tried on my Samsung TV and it works fine...
    07-05-2016 01:00 PM
  10. Alanhd's Avatar
    Yeah mine works perfect on my Samsung TV as well. its a pity the OP doesn't know someone with another S7e to test it to eliminate the TV.
    07-05-2016 01:22 PM
  1. Verizon won't activate my Moto X Pure!!!
    By Bradmeister2008 in forum Moto X Pure Edition
    Last Post: 07-08-2016, 02:19 PM
  2. Why does rooting my phone break google play every time
    Last Post: 06-30-2016, 01:23 PM
  3. help me unlock my phone using google account?
    Last Post: 06-29-2016, 05:23 PM
  4. How do you unsync a phone that is connected to mine.
    Last Post: 06-29-2016, 04:05 PM
  5. GPS in Iceland
    Last Post: 06-29-2016, 03:55 PM
