1. lammy8's Avatar
    Can somebody confirm as to whether the S7 edge states it is fast charging when you connect it to a quick charge 2.0 charger (not the Samsung adaptive fast charger it came with). I've heard it does support quick charge 2.0 and want to buy a twin port QC2.0 plug but don't want to buy one and find out it doesn't work.
    Thanks
    06-29-2016 05:30 PM
  2. Aquila's Avatar
    The S7 Edge does support Quick Charge 2.0.
    06-29-2016 05:51 PM
  3. dpham00's Avatar
    Yup it should work fine.
    06-29-2016 06:06 PM
  4. lammy8's Avatar
    I know it supports it guys and thanks for getting back to me.
    I'd just like a definitive confirmation that the device states it is fast charging when connected to a QC2.0 charger
    Thanks
    06-30-2016 05:34 PM
  5. flstructuraleng's Avatar
    Yes... it actually states that on the screen, while charging, as opposed to just "charging" with a regular charger.
    Aquila and lammy8 like this.
    06-30-2016 05:43 PM
  6. AndroidVic's Avatar
    If your asking about the phone reporting it, as everyone says, Yes it does. But then you ask mention about using a different charger. If you want fast charging you do need to use the Adaptive Fast Charger. Otherwise, it will charge faster but not fastest.
    If you look at the power supplies you will see the regular ones have 5v 1.x amp and 5v 2.x amp. That is not going to give you the fastest charge. It needs to say 5.v 2.x amp & 9v 1.x amp.
    07-01-2016 08:38 AM
  7. imex99's Avatar
    Using adaptive fast charger and not getting it on charging when.... Any ideas? It's on in settings....
    I rebooted phone and turned on and off, working now!
    07-01-2016 12:46 PM
  8. farhanmohd's Avatar
    Can I use quick charge 3.0 charger with s7 edge
    07-03-2016 03:17 PM
  9. Aquila's Avatar
    Yes it will function as QC 2.0.
    07-03-2016 03:53 PM
  10. lammy8's Avatar
    Gave in and bought a QC 2.0 charger. It definitely states and does fast charge. Not seen whether it's any faster or slower than Samsung's adaptive fast charger. Swear it's just another marketing name for no reason.
    07-10-2016 03:12 PM
  11. joebogey's Avatar
    You can thank trademarks for that. I have a Tronsmart Quick Charge 2.0 54W 4-Port USB Car Charger https://www.amazon.com/dp/B00ZF7XLJU...cUvbUpU5260654 that I got when I still had my S4. With the S7 Edge when plugged it in reports as Fast Charging.
    07-11-2016 05:06 PM
  1. The rumored USB Type-C port on the Note 7
    By D13H4RD2L1V3 in forum Samsung Galaxy Note 7
    Last Post: 09-06-2016, 02:03 PM
  2. New HTC 10.. A few questions
    By NightOrchid in forum HTC 10
    Last Post: 07-10-2016, 03:24 PM
  3. Phone shuts off despite plenty of charge and changes time.
    Last Post: 06-29-2016, 03:43 PM
  4. factory reset questions
    By PinkLipstick in forum Samsung Galaxy Note 5
    Last Post: 06-29-2016, 02:54 PM
  5. My lenovo p1m40 mobile taking charge in switch off mode.
    Last Post: 06-29-2016, 06:05 AM
