Didn't your wireless charger come with the Samsung Adaptive Fast Charging plug and USB cable (same ones that the phone came with)? Mine did. You can buy an extra on Amazon (as well as Samsung Adaptive Fast Charging car chargers), if need be.
Even though Samsung says they haven't heard about it (people obviously aren't reporting it to them), there is a problem with some phones (including mine) not having the wireless charging feature work correctly. It takes over four hours for mine to fast wireless charge from about 5%. Unfortunately, the fix is to send your phone to Samsung for repair, which means they will factory reset it. That's not something I am willing to go through, so I will live with the slow wireless charging. Wired charging works normally, so if I need to charge fast, I will just do that.
Do try using the correct charger first, though!
