11-03-2016 08:10 AM
27 12
tools
  1. KBx315x's Avatar
    I decided to purchase a Samsung wireless "fast charger" so far this thing is not so fast. I'm not using the charger that came with my phone but the block piece is a 2.1 Amp charger. Any suggestions? It looks like from 15% to 100% its going to take a little over 3 hours. Is this normal? Thanks!
    06-30-2016 09:27 PM
  2. cwbcpa's Avatar
    That doesn't sound normal. I don't have a wireless charger for my s7 edge but when I used one with my Note 5 it charged from about 20% to 100% in about an hour or maybe a little longer. I used the Samsung wall plug with the wireless charger though.
    06-30-2016 09:33 PM
  3. KBx315x's Avatar
    Thanks for the feedback Ill see if I can find my samsung charger I feel like I lost it though
    06-30-2016 09:35 PM
  4. chanchan05's Avatar
    The Samsung fast wireless charger needs to be used with the fast charger plug to get fast charging.
    BillGastonJr likes this.
    07-01-2016 01:57 AM
  5. marzfreerider's Avatar
    Make sure you have the fast charge turned on in settings. Go to Apps then settings, down to accessories make sure the fast charge is turned on. Hope this helps.
    Posted with my S7 edge via the Android Central App
    rdubmu and Shamshi-Adad like this.
    07-01-2016 02:11 AM
  6. Almeuit's Avatar
    Does the phone read "Fast Charging Wirelessly" when on the pad? It should if it is charging fast via wireless.
    07-01-2016 02:19 AM
  7. Bag of Leaves's Avatar
    Didn't your wireless charger come with the Samsung Adaptive Fast Charging plug and USB cable (same ones that the phone came with)? Mine did. You can buy an extra on Amazon (as well as Samsung Adaptive Fast Charging car chargers), if need be.
    Even though Samsung says they haven't heard about it (people obviously aren't reporting it to them), there is a problem with some phones (including mine) not having the wireless charging feature work correctly. It takes over four hours for mine to fast wireless charge from about 5%. Unfortunately, the fix is to send your phone to Samsung for repair, which means they will factory reset it. That's not something I am willing to go through, so I will live with the slow wireless charging. Wired charging works normally, so if I need to charge fast, I will just do that.
    Do try using the correct charger first, though!
    07-01-2016 05:10 AM
  8. AndroidVic's Avatar
    So...where did you buy it from? Right now, there are TONS of fakes on EBay that say fast charge but arent. EBay is a mecca for knock-offs from China.
    And......did it come with its own power supply? Many do not. If you do not use the right power supply it won't fast charge. When it comes to supplies...there is fast charge and really fast charge. Look at the power supply. Does it say 5v 1amp and 5 v 2 amp? If it does, its not the Adaptive Fast Charger. It needs to say 5v 2amp and 9v 1.x amp. If it does not put out the 9v, you will not get the really fast charge.
    And finally..on the S7 for example, you need to turn on Fast Wireless Charging. (Settings/System/Accessories). If you do not turn it on..it will fast charge wired but not wirelessly.
    07-01-2016 08:30 AM
  9. meyerweb#CB's Avatar
    This ^^^
    rdubmu likes this.
    07-01-2016 03:21 PM
  10. tsells's Avatar
    My phone is great, and fast wired charging works perfectly. However, fast wireless charging does not work for me either (using the Samsung fast charge stand).
    I do not want to replace the phone as everything else is perfect, so I also just use a wired fast charger.
    Bag of Leaves likes this.
    07-01-2016 03:29 PM
  11. AndroidVic's Avatar
    Wireless Fast Charge turned on?? Settings/Systems/Accessories
    rdubmu likes this.
    07-01-2016 06:27 PM
  12. csleverette's Avatar
    Cases can effect the fast wireless charging. If you have a case take it off and see if that makes a difference for you. We tested 3 different cases and that's what it turned out to be. Good luck.
    07-01-2016 08:06 PM
  13. Bag of Leaves's Avatar
    Sorry to hear you have the same problem! I originally thought it was a problem with the wireless charging stand, so exchanged it for a new one (Amazon), but had the same results. It works with a family member's Note 5 just fine, so that's what really confirmed it was my phone that was the problem. Like you, everything else works, so I will just deal with the wireless charging problem. I almost always charge it overnight anyway, so not a huge deal.
    07-02-2016 01:42 AM
  14. Bruins11's Avatar
    I am having this issue as well. Sent Sammy and email but haven't heard anything back. When i want it to charge fast I just use the cable and unplug it from the base. Kinda defeats the purpose.
    07-02-2016 07:01 AM
  15. rdubmu's Avatar
    Before anyone else responds several people have stated you need to turn on fast wireless charging in setting. Check that before anything else. Post a screen shot please.
    07-02-2016 08:28 AM
  16. Almeuit's Avatar
    Those with the issue ensure you don't have a very thick case. Also as said above ensure fast wireless charging is turned on within the options.
    07-02-2016 02:01 PM
  17. tsells's Avatar
    I tried without a case.
    I definitely have fast wireless charging turned on.
    It also says fast wireless charging when put on the stand (and this is my second stand as I returned the original one because I was getting the same results).
    I just tried to use the wireless stand again. My battery was at 76% and when put on the stand it said that it would be full in about 38 minutes. But after 30 minutes it was only at 82% and then said it would be full in 27 minutes. After another 30 minutes it was at 90%, and then went to 98% in another 30 minutes. So it took 90 minutes to go 22%. If I used the same wire plugged directly into the phone I can charge my phone from 30% to full in around an hour!
    07-02-2016 03:16 PM
  18. Bag of Leaves's Avatar
    It should default to being on the first time you use it. It is quite obvious when it is on because it tells you it is fast charging wirelessly when you place it on the wireless charger.
    07-03-2016 03:32 AM
  19. Bag of Leaves's Avatar
    Wireless charging does work with many cases, but most people have tried it with and without cases and with the phone turned off - all sorts of scenarios. Saying the option needs to be turned on a thousand times per thread about this issue doesn't need to happen.
    07-03-2016 03:36 AM
  20. Bag of Leaves's Avatar
    Those who are having the wireless charging problem, what carrier do you have and when did you buy your phone? I have Sprint and bought it online in April (it was backordered for a few days). Black S7 Edge. I am just wondering if we all got our phones from the same lot.
    07-03-2016 03:39 AM
  21. Kristian Nikolov's Avatar
    I have the same issues with the wireless charging stand. Haven't tried the stand with another phone or the phone with another wireless charger. The phone is s7 edge exynos european.
    07-03-2016 06:15 AM
  22. tsells's Avatar
    Black S7 Edge bought mid March on AT&T.
    07-03-2016 10:26 AM
  23. Almeuit's Avatar
    I was simply attempting to help. Checking both of those should allow it to work. My phone didn't initially work till I turned the option on. Since I have.. I use my wireless pad all the time and it fast charges.
    As for the case thing I agree it works with most but it's still a thing to check because we don't know what they have. Please don't get snippy over people attempting to help with limited information. Thanks.
    07-03-2016 12:07 PM
  24. Almeuit's Avatar
    You can snag one for cheap on amazon. Around $9.
    https://www.amazon.com/dp/B00WXO16TU...cUvbUpU5249731
    07-03-2016 12:11 PM
  25. WallaceD's Avatar
    I have this charger and I use it with the Samsung adaptive charger that came with the S7E.
    Using it with a Mediabridge USB cable, it will fast charge my Edge without any problems. Charging time is excellent. Right now my phone is at 58% and it is saying it will be fully charged in 1 hr 5 mins. YMMV, of course.
    I like this particular charger because it has an LED that indicates whether fast charging is on or off. If it's blue, fast charging is happening. If it's green, it's normal charging.
    My phone is in this Unicorn Beetle case and I've never had a problem with it preventing fast charging.
    I think the key to successful fast wireless charging is using the Samsung adaptive charger (or a high quality replacement), a good quality fast wireless charger purchased from a reliable source, a decent USB cable, making sure the phone is positioned correctly and, if applicable, making sure the case is not interfering.
    07-03-2016 01:34 PM
27 12
  1. Samsung S7 Edge from sprint to Boost Mobile Network.
    By wireless shack in forum Samsung Galaxy S7
    Last Post: 07-08-2016, 04:42 PM
  2. Replies: 2
    Last Post: 07-04-2016, 11:18 PM
  3. How can I reset my WiFi pass Word on Samsung S5 T-800
    Last Post: 06-30-2016, 09:41 PM
  4. Replies: 1
    Last Post: 06-30-2016, 08:19 PM
  5. Replies: 1
