1. Bob4seven's Avatar
    I have been using Zedge ringtones for all my contacts. But all of a sudden and reverted to default. I tried resetting it it just refuses to use Zedge. Anybody got an idea? I have tried everything.
    07-02-2016 02:49 AM
  2. B. Diddy's Avatar
    Are the ringtones saved to the Ringtones directory on Internal Storage, or are they on an SD card?
    07-02-2016 11:58 PM
  3. Bob4seven's Avatar
    Internal storage. When I go to contacts choose a contact scroll down to ringtone and try to change the ringtone from the fault using the Zedge storage ringtones it just goes back to default.
    07-03-2016 02:13 PM
  4. B. Diddy's Avatar
    Can you try uninstalling Zedge, then reinstalling it and downloading those ringtones again?
    Alternatively, use My Files to copy the ringtones from the Zedge directory to the Ringtones directory, and see if that works.
    07-03-2016 04:16 PM
  1. Why am I not receiving notifications from news apps?
    Last Post: 07-11-2016, 04:28 AM
  2. Problems if firmware is not updated
    By theadvocate_ivan in forum Samsung Galaxy S7 edge
    Last Post: 07-07-2016, 01:53 PM
  3. Screen capture still doesn't work.
    By Jsreaves in forum Samsung Galaxy S6
    Last Post: 07-02-2016, 01:40 PM
  4. Why does my tablet keep saying my games are not compatiable
    Last Post: 07-01-2016, 11:30 PM
  5. Replies: 0
    Last Post: 07-01-2016, 05:31 PM
