1. rnich120's Avatar
    Hi guys,
    I just wanted to see if anyone else has noticed some slowdown/lag with their unit.
    I have a feeling that its going to be relating to the SD card...
    I don't restart that often and i do close apps / clear the ram as often as possible (When i remember).
    Its getting a little annoying. Main time is when I connect to my cars bluetooth system and then waze will automatically start. The phone hangs and doesn't respond for about 30 seconds and is just super slow...Pulling down the notification shade is also slow and it hangs....
    Any ideas would be great.
    07-02-2016 04:06 PM
  2. t11rmh's Avatar
    Clear the cache partition and reboot your phone regularly. Uninstalled apps you don't use.
    Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
    07-02-2016 04:31 PM
  3. chanchan05's Avatar
    How exactly are you clearing RAM? Are you using a speed boost app? And clearing RAM is actually a cause for slowdown on Androids.
    07-02-2016 05:37 PM
  4. edubb256's Avatar
    Not sure why you are closing apps and clearing RAM, but doing that tends to slow it down.
    cwbcpa likes this.
    07-02-2016 08:31 PM
  5. ogio's Avatar
    yes! i've been noticing the same thing. phone is just slow to transition between apps and such. and i have the animation time turned off in the developer options. still have the sd card issue, so it may be why.
    07-02-2016 11:28 PM
  6. Bag of Leaves's Avatar
    You can set the phone to restart once a week (like while you're sleeping), which is good for it. (I think there's one phone carrier that took away that feature, if I remember correctly from another thread.) As others said, clearing the RAM and closing apps actually slows the phone down. There was an article about it that I recently read that explained why.
    07-03-2016 03:45 AM
  7. chanchan05's Avatar
    If you're using the Snapdragon version, it was seen in several tests to be quite inferior to the Exynos version in terms of multitasking. A video comparison by Phonebuff actually had it almost a full 40 seconds slower than the Exynos to do the same set of tasks, if I remember correctly.
    07-03-2016 07:27 AM
  1. Are slowdowns common on Android ?
    By bitek in forum General News & Discussion
    Last Post: 06-20-2016, 10:25 AM
  2. Camera and other slowdowns.
    By johnj2803 in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 10:06 PM
  3. Messaging App Slowdown/Lag
    By David Rosen in forum Samsung Galaxy Note 5
    Last Post: 11-30-2015, 03:03 AM
  4. Phone Slowdown
    By henryfool3 in forum HTC One M8
    Last Post: 11-01-2015, 12:59 PM
  5. frequent freezes, slowdowns, lockups?
    By aapold in forum SHIELD Tablet
    Last Post: 05-09-2015, 11:35 AM
