07-17-2016 01:05 PM
37 12
tools
  1. Doc Marten's Avatar
    My battery life was great until two days ago and now it's horrendous and I've no idea why. I haven't downloaded anything. It's gone from using next to nothing overnight - 2% - to using 25%. A huge jump and it's like it was in the first week or two. I haven't installed anything but a few Google apps updated themself a couple of days ago.
    07-14-2016 06:05 AM
  2. popkurn611's Avatar
    Have you done a security update recently?
    I think I am noticing that since the june security update I did, the battery doesn't seem as great. I am on AT&T, anyone else concur?
    07-14-2016 10:23 AM
  3. Waipio11's Avatar
    My June Verizon update killed mine.
    07-14-2016 07:23 PM
  4. popkurn611's Avatar
    I'm thinking the same thing happened to me. Lucky u, Verizon just sent out the July update
    07-14-2016 07:36 PM
  5. Doc Marten's Avatar
    What security are you meaning?
    07-14-2016 07:39 PM
  6. Waipio11's Avatar
    Just found that one. Will wait to get home and remove my sd card first.. As update wiped out my card.
    07-14-2016 07:40 PM
  7. jeetu4444's Avatar
    Yeah I had same problem...but as I had faulty display..I sent it for warranty...and told them battery life was bad as well...They changed my display and battery. Now battery life seems very good..2 days to 1 day few hours after I installed all my apps..obviously my phone was wiped out to factory reset and latest firmware
    posted from Limited red and gold Lumia 950, Beautiful S7 Edge gold or Surface pro 4
    07-14-2016 08:14 PM
  8. chanchan05's Avatar
    Just got the July update and my standby time improved by more than two hours. Nice. GSAM still reports the same screen on time used during the day, but overall battery consumption decreases. I used to be able to expect 15-16hrs standby time with 4-5hrs screen on time and data left on (in a hospital with lots of walls between you and outside that's not a good idea), now I get readings of >18hrs standby time.
    07-17-2016 04:58 AM
  9. popkurn611's Avatar
    U on Verizon?
    07-17-2016 10:44 AM
  10. Rose4uKY's Avatar
    Ok I work in a hospital basement with horribe signal but am always on wifi and don't always stay in the basment. I used to leave work after 8 hours with 30% or so and never have to charge my phone at work. I got the July update and am with Sprint and am guessing that did it. I was down to 5% last night and had to charge my phone. It's been happening alot lately and I used to never have to charge my phone at work. My friend leaves her location on all day and gets great battery life much better than me. I don't know what happened all of a sudden or if it's an app causing it. I did set my phone to restart once a week to help and I cleared out cache but I know their is another way to go into some mode and clear cache too but I forgot how.
    Also under battery what is this app power saving mode do I leave it on it says saves power after an app isn't used for 3 days. Mine's been on and than I found optimize batter usage do I turn that on for apps I have unlimited data also but it says turn on for individual apps to save power. Just trying to figure out what happened all of a sudden. And I would like to be able to leave my location on all day I leave it on the the middle one alot cause I check in not on the GPS one. if that makes a difference on battery I don't know. Just mad cause I got great battery life in the beginning.
    07-17-2016 10:49 AM
  11. chanchan05's Avatar
    U on Verizon?
    Nope. Not even in the US.
    Sometimes updates cause cache conflicts for whatever reason making some systems go eat up a lot of battery. You need to clean out system cache.
    Turn off the phone then press power+home+volume up. Let go of power when you see the Samsung logo, but keep on pressing home+volume up. You'll get to a recovery mode where you can clear out system cache. Just be careful that you don't accidentally select factory reset.
    07-17-2016 11:48 AM
  12. Roman Akert's Avatar
    Battery remaining at time was 15% (Battery Saver kicked in at that percentage).
    Model G935F running TW. Auto brightness approx. 40 - 50%. Wifi on, Location off.
    07-17-2016 01:05 PM
37 12
  1. Do galaxy s7 headphones not work on ipods?
    Last Post: 07-05-2016, 01:43 PM
  2. Facebook using battery even though it's been disabled
    By dizzle16 in forum Samsung Galaxy S7
    Last Post: 07-05-2016, 11:56 AM
  3. Replies: 1
    Last Post: 07-05-2016, 08:19 AM
  4. Replies: 0
    Last Post: 07-05-2016, 07:55 AM
  5. Replies: 0
    Last Post: 07-05-2016, 07:30 AM
