1. Cory S's Avatar
    So, randomly one day my S7e started to take forever to charge (6+ hours) I noticed it was reporting it was charging at USB speeds instead of fast charging, so I made sure fast charging was enabled. (it is). Then I tried several other chargers and cables...same result. I even tried a factory reset...nothin.
    Anyone else seen this before?
    07-05-2016 01:13 PM
  2. B. Diddy's Avatar
    Check the microUSB port to see if there is any debris in there. Blow it out with a can of compressed air, and use a cotton swab dipped in rubbing alcohol to clean off the contacts.
    If the problem persists, the port itself might be faulty. Bring it back to the store and ask for an exchange--if they can't or won't help, then contact Samsung for warranty repair.
    07-05-2016 02:51 PM
  3. chanchan05's Avatar
    Or you can try a different charging block.
    07-05-2016 02:51 PM
  4. B. Diddy's Avatar
    I believe the OP already has (he mentioned "chargers and cables," which I assume includes the charging block).
    07-05-2016 03:58 PM
  5. chanchan05's Avatar
    For some reason I initially read that as just cables. Lol.
    B. Diddy likes this.
    07-05-2016 05:54 PM
  1. camera quality worse than Edge+
    By NightOrchid in forum Samsung Galaxy S7 edge
    Last Post: 07-07-2016, 12:24 PM
  2. Why is Google Play Music only uploading parts of songs?
    Last Post: 07-06-2016, 07:38 AM
  3. Why file transfer over USB C slower than USB 3.0
    Last Post: 07-05-2016, 08:45 PM
  4. Why do callers hear an echo when calling me on my S7?
    Last Post: 07-05-2016, 03:32 PM
  5. Twitter account shows up at top of Share To list
    By lspomob in forum Ask a Question
    Last Post: 07-05-2016, 12:19 PM
