Bigger screen. 5.5 inches compared to 5.1. Also a bigger battery, 3600mah compared to 2600mah. A friend who has an S6 Edge says that he finds the S7 Edge pictures better. His GF has one so he can have a lot of comparison.
Not sure if it has a higher screen res, can't remember. I like it best for the Game Center. I play simple games like CoC, Clash Royale, Subway Surfers, and I sure as hell don't need the entire power of the phone for those. Thr power saving options (resolution, texture and fps limiter) helps a lot in reducing gameplay battery usage.
One con is smaller onboard memory. S7 models only has 32GB + SD card. S6 models reach up to 128GB.
07-06-2016 10:27 PM
