1. Pain_dont_hurt's Avatar
    Going on a trip to Scotland and London next week. Are there any useful apps I should download before heading there to help make my trip run smoothly? Thank you
    07-07-2016 08:29 AM
  2. Golfdriver97's Avatar
    What did you have in mind?
    07-07-2016 08:35 AM
  3. osubass1's Avatar
    i was in London recently. Android Pay support for TfL had just been added. get an Oyster account, add it to your Android Pay and enjoy the trip.
    Golfdriver97 likes this.
    07-07-2016 08:45 AM
  4. belodion's Avatar
    Grab a London Underground map app. It's a fascinating multi-colored network of different lines.
    Golfdriver97 and VDub2174 like this.
    07-07-2016 08:56 AM
  5. osubass1's Avatar
    rather than using an Underground map, i used Google Maps. it tells you exactly which lines to take and how many stops in between.
    not sure if you're on the Google Trip beta, but that's a nice app to have if you've never visited a particular area before.
    07-07-2016 09:13 AM
  6. the tall guy's Avatar
    As for Scotland - give this app a bash.
    https://play.google.com/store/apps/d...velineScotland
    It's useful for all transportation times throughout scotland.
    07-07-2016 09:37 AM
  7. the tall guy's Avatar
    07-07-2016 09:39 AM
  8. Javier P's Avatar
    This is not an app idea, but if you don't have a roaming plan or don't want to spend too much on mobile connection, you could buy a local prepaid card. They are quite cheap and for a few pounds you can get 500mb. I use to buy from Vodafone on my trips to UK.
    07-07-2016 09:42 AM
  9. tshirttan408's Avatar
    If you want a useful travel app for London Citymapper is the way to go, best routes and has a tube map included as well. Hands down the best app for getting around the big smoke.
    07-08-2016 03:28 AM
