What previous platform are you coming from? We can better assist you knowing that, as different platforms may mean that you are accustomed to certain things. Here is a quick list of what to do after setting up all your preliminary accounts:
- write down or recall your most used apps from your previous platform; then look for the equivalent in the Google Play app store. It's a very extensive app database, so if you can't find the exact same app as before, I am sure you'll be able to find the next best thing
- set up the phone in the way that makes you most comfortable. Make folders, change wallpapers - make it yours and easy to use. Don't worry about launchers or anything extra until you're more used to it.
- go through your "Settings" app and see what you can manage about your phone to make it better suit your needs (ie, battery percentage icon, display brightness, home screen versus lock screen).
- if all else fails, YouTube can show you how to do a ton of stuff!
Congratulations on your new phone, and welcome to the Android world! If you need anything else, please let us know.
