1. miguelskaff's Avatar
    Hello guys,
    I just bought an s7 edge over a month ago and i find that the intensity of the brightness is very poor even in max with or without the auto option on. I don't have power saver on and i also have an iPhone 6 Plus and the difference is very notable. I also compared it with a friend's note 5 and another s7 edge and you can see a clear difference. Any ideas?
    Thanks!
    07-10-2016 09:07 AM
  2. chanchan05's Avatar
    If it's not as bright as another S7 Edge, you may want to have it checked, but since you waited over a month I don't think you're going to get it replaced for free.
    07-10-2016 09:55 AM
  1. Auto Brightness Problems After Marshmallow
    By agolz12 in forum Samsung Galaxy S6 active
    Last Post: 08-16-2016, 11:35 PM
  2. Why isn't my brightness settings doing anything?
    Last Post: 07-08-2016, 03:02 PM
  3. samsung s5 low battery shutoff... wont restart. total brick
    By japanesezero in forum Samsung Galaxy S5
    Last Post: 07-01-2016, 02:36 AM
  4. Screen brightness.
    By eric002 in forum Nexus 6P
    Last Post: 06-29-2016, 08:45 PM
  5. Why is my Bluetooth volume so low in the car?
    Last Post: 06-28-2016, 10:00 PM
