1. buzeavlad's Avatar
    Hello! I have a Samsung Galaxy S7 Edge with a clear view cover.
    This cover makes it pretty hard to hold the phone with one hand while taking photos with the rear camera. The camera app lets you take photos using the volume buttons, but when you close the lid to have a better grip on the phone, the screen turns off and the volume buttons do not trigger the camera anymore.
    Is there a way to overcome this? Something like setting the phone to ignore the cover?
    07-11-2016 04:18 AM
  2. mstrblueskys's Avatar
    Photography is why I've taken every flip cover off every device I've used. Dot View on HTC, Flip on Asus, Wallet on Windows, they all wreck the photography of the phone if you're trying to get pics quick.
    The best answer is that you should get a new case.
    You might be able to find magnets in the case that you could remove and you might be able to interact with the phone without those in the cover, but you're more likely to wreck things rather than fix them by doing this, but if you're going to get a new one anyway, it might be worth a shot?
    07-11-2016 12:59 PM
  1. Replies: 7
    Last Post: 07-15-2016, 04:55 AM
  2. Keeps asking me to sign into google, but wont sign in
    Last Post: 07-11-2016, 06:58 AM
  3. Is there any apps that act like a scanner/copier for smartphones
    By Vanessa Brooks1 in forum Ask a Question
    Last Post: 07-11-2016, 06:37 AM
  4. Replies: 2
    Last Post: 07-11-2016, 05:33 AM
  5. Replies: 0
    Last Post: 07-11-2016, 02:47 AM
