1. Andyvalver's Avatar
    I tend to charge my phone overnight so I do not use fast charge. However, with this turned off the predicted time of charging from the phone varies massively. I can plug the phone in and it will say 1hr 45min until full. If I remove the cable and then reinsert it it can change to 4 hours to charge. Sometimes I have woken up to it not fully charged. One message from the phone suggested I use the proper charger as it's slow charging. I was using the proper charger. See the screenshot.
    Posted via S7 edge ๐Ÿ˜
    Attached Thumbnails Galaxy s7 edge charging issue.-8390.jpg ย
    07-12-2016 06:04 PM
  2. jeetu4444's Avatar
    Are u using original samsung charger...if so , are u have voltage fluctuations...check that..
    posted from Limited red and gold Lumia 950, Beautiful S7 Edge gold or Surface pro 4
    07-12-2016 06:49 PM
  3. chanchan05's Avatar
    It could be the socket. The phone is only reading estimated time based on the inflow of current.
    07-12-2016 10:09 PM
  4. Andyvalver's Avatar
    I'm using the Samsung charger that came with it. I don't have any issues if I leave it on fast charge. Is just strange how I can plug the phone in and get a time estimate, then do it again and get a completely different time estimate and then it says it's slow charging. I never knew slow charging was even an option. Thought it was normal charging or fast charging.
    07-13-2016 03:36 AM
  5. osubass1's Avatar
    i had a very similar issue.
    i was using the regular Samsung fast charger that came with it, and i noticed that it would sometimes get done super quick and other times it would say "fast charging," but it would estimate 3 - 4 hours. some mornings, i would wake up and it wouldn't be completely charged, usually being stuck around 76%.
    i moved to a different outlet, same thing.
    i switched to another Samsung fast charger, and it worked as expected. i left the original one unplugged for several days in that time assuming it was tired of charging.
    out of curiosity, i tried it one last time before deciding to get rid of it, in the same original outlet, and it started working as per normal.
    i have no idea what the moral of the story is here, but i assume your issue is likely related to the charger, itself.
    07-13-2016 08:28 AM
  6. Andyvalver's Avatar
    Glad I'm not the only one. I'll try unplugging the charger and leaving it for a while then plug it back in again. I don't have the issue when the phone is set to fast charge. Just when it's not. Cheers.
    07-14-2016 11:25 AM
  1. Replies: 30
    Last Post: 07-14-2016, 11:51 AM
  2. s7 active warranty
    By Rds030903 in forum Samsung Galaxy S7 Active
    Last Post: 07-13-2016, 07:18 PM
  3. Zauba listing Shows Waterproofing For the Galaxy Note 7!
    By Preach2k in forum Samsung Galaxy Note 7
    Last Post: 07-12-2016, 05:12 PM
  4. Why can't I save to my galaxy s7 sd card?
    Last Post: 07-12-2016, 04:27 PM
  5. Replies: 0
    Last Post: 07-12-2016, 04:07 PM
