1. AC Question's Avatar
    Phone will not ring or vibrate on incoming calls. All calls will ring (for the caller) but then go to voicemail. I have had someone tell me they kept getting a busy signal. I don't know how long this has been going on; I don't get a lot of calls, but I'm on call today and that is how I found out. Had my husband and daughter stand next to me and call my phone. Doesn't go straight to voicemail; rings 4-6 times, then voicemail.
    I have restarted my phone, but haven't removed the battery (don't know how on this phone).
    07-12-2016 07:12 PM
  2. dpham00's Avatar
    Try to disable do not disturb mode from the notification pull down.
    07-12-2016 07:51 PM
  3. 06purple18's Avatar
    My son has an S6. Someone told him to change his ringtone and it would fix it temporarily. Apparently the last update is the problem and no one knows how or why yet. I changed ringtones and it worked!
    07-12-2016 08:20 PM
  4. Wings86's Avatar
    I had the same problem recently and tried several fixes including a factory reset. None of them worked. On a whim I enabled wi-fi calling and made a test call and the phone rang as normal. I then turned off wi-fi calling and now the phone rings for normal calls too. I don't know why it worked but its been working fine now for 2 weeks.
    2thman likes this.
    09-12-2017 11:09 AM
  5. 2thman's Avatar
    This worked!
    I had returned from an overseas trip and wifi was off, but used on again and then turned off and it works. For now at least.
    Sprint support had me update PRL, etc, restart but that only worked for 1 call.
    Thanks, Wings.
    06-09-2018 10:49 AM
  1. Galaxy s7 edge charging issue.
    By Andyvalver in forum Samsung Galaxy S7 edge
    Last Post: 07-14-2016, 12:25 PM
  2. s7 active warranty
    By Rds030903 in forum Samsung Galaxy S7 Active
    Last Post: 07-13-2016, 08:18 PM
  3. Rear Camera not working and front camera is reversed
    By samoldland_123 in forum General Help and How To
    Last Post: 07-13-2016, 05:44 PM
  4. Zauba listing Shows Waterproofing For the Galaxy Note 7!
    By Preach2k in forum Samsung Galaxy Note 7
    Last Post: 07-12-2016, 06:12 PM
  5. Replies: 0
    Last Post: 07-12-2016, 05:58 PM
