1. tracypagedotnet's Avatar
    Anyone else have issues with screen rotation? I've thrown this piece of garbage at the wall 5 times this morning and the screen still won't rotate.
    07-14-2016 06:36 AM
  2. cwbcpa's Avatar
    100% buyers remorse...the S7E is hands down the crappiest phone I have ever owned and I've had 3 iphones!!!!!
    I'm sure you have checked this, but have you made sure that autorotate is on and the phone is not in portrait mode?
    07-14-2016 07:18 AM
  3. tracypagedotnet's Avatar
    I have...
    It's not a 24/7 issue...just sometimes the screen will not rotate?!?!?
    07-14-2016 07:19 AM
  4. cwbcpa's Avatar
    It's not a 24/7 issues either...just sometimes the screen will not rotate?!?!?
    So I assume that means you checked the autorotate to make sure it's on when it's not rotating? If so, I would try resetting the phone. Sometimes that is all it takes.
    I've had this happen with my iPhone and a reset fixed it.
    07-14-2016 07:28 AM
  5. pjwk81's Avatar
    On Youtube I always have to rotate twice before the screen does. Never picks up the first time.
    tracypagedotnet likes this.
    07-14-2016 07:50 AM
  6. tracypagedotnet's Avatar
    Perhaps this is an issue with the FB and/or messenger app? I can't recall any other specific app that "fails" with such frequency....
    07-14-2016 08:34 AM
  7. tracypagedotnet's Avatar
    Sure, that resolves 99% of electronic problems...and rebooting once every 48 hours or so isn't "extreme" per say, but it does see a bit too frequent to me....
    07-14-2016 08:37 AM
  8. tracypagedotnet's Avatar
    ...and obviously this is an issue at 5:30am when grabbing my phone off the night stand and checking social media before actually getting out of bed to star the day
    07-14-2016 08:40 AM
  9. cwbcpa's Avatar
    I didn't say rebooting and I definitely didn't say every 48 hours. I said reset the phone completely. One time. That's all. Resetting means setting it up as new all over again. You definitely shouldn't be doing it every 48 hours. I agree that's extreme.
    Like I said, I had to do it with my iPhone and it fixed the issue.
    07-14-2016 08:40 AM
  10. tracypagedotnet's Avatar
    I gotcha...no I have not done a "reset", but I am in the process of backing up my SD card to try the adaptable storage "tweek",.....might be a good time
    07-14-2016 09:11 AM
  11. tracypagedotnet's Avatar
    07-14-2016 08:39 PM
  12. urbhusker's Avatar
    My auto rotate toggles off by itself. I have to repeatedly go into settings to turn it back on.
    07-14-2016 10:01 PM
  1. Nexus 5X cannot restart after screen freeze
    By Maxace in forum Nexus 5X
    Last Post: 07-15-2016, 07:41 PM
  2. Replies: 1
    Last Post: 07-15-2016, 10:57 AM
  3. No command signal on my screen, why?
    By AC Question in forum HTC Desire 816
    Last Post: 07-14-2016, 05:33 AM
  4. Are all LG G4 screens and frames compatible?
    By AC Question in forum LG G4
    Last Post: 07-14-2016, 05:08 AM
  5. unlock screen, emergency call comes up
    Last Post: 07-14-2016, 12:11 AM
