1. nonie's Avatar
    Has Samsung put data on menu at top of phone? Or do you still have to go into setting, to more data, to turn on and off?
    Posted from Android Central.
    on Samsung Galaxy s5
    07-18-2016 03:52 PM
  2. SpookDroid's Avatar
    Still have to go through the Settings menu, no quick toggle. It's gone from the power menu as well. I guess you could turn it off with UltraPower Saving Mode, but that's not the only thing that would be toggled in that mode.
    07-18-2016 04:25 PM
  3. dpham00's Avatar
    It is there on the Verizon variant...which variant do you have?
    SpookDroid likes this.
    07-18-2016 05:32 PM
  4. Almeuit's Avatar
    Not on the T-Mobile one. You have to have a widget or go into settings (nothing in the notification panel).
    07-18-2016 05:46 PM
  5. nonie's Avatar
    I'm still using samsung galaxy s 5.
    07-18-2016 05:49 PM
  6. alarsen7's Avatar
    I also have the verizon S7e and it has mobile data available as a toggle in the notification panel as well.
    07-18-2016 06:45 PM
  7. Almeuit's Avatar
    Yep Verizon leaves that toggle and a nice hotspot toggle. The others remove it which is annoying .
    07-18-2016 08:47 PM
  8. dpham00's Avatar
    Does the unlocked one have it?
    07-18-2016 11:16 PM
  9. vientiane's Avatar
    Yeah, the unlocked version also have that.data-screenshot_20160719-021345-1-.jpg
    07-19-2016 02:16 AM
  10. dpham00's Avatar
    Nice. It looks like att (and tmobile too ?) like to mess around with the toggles
    07-19-2016 03:28 PM
  11. speedtrap63's Avatar
    Verizon S5 still has the Mobile data toggle in the Quick settings.
    07-19-2016 06:40 PM
  12. optimummind's Avatar
    You cam have the data toggle if you use the Samsung Goodlock app.
    07-20-2016 01:11 AM
  1. How to access data on unlocked GS5 with dead screen?
    Last Post: 07-27-2016, 06:56 AM
  2. Got a problem with background data on S7
    Last Post: 07-18-2016, 03:59 AM
  3. Replies: 1
    Last Post: 07-17-2016, 09:34 PM
  4. Nexus 5x MOBILE DATA TURN ON/OFF
    Last Post: 07-17-2016, 06:41 AM
  5. Can I Get Free Data To Play Pokemon Go?
    Last Post: 07-17-2016, 04:19 AM
