1. AC Question's Avatar
    how do I clear all entries from my calendar? I am using the calendar app that came already installed on the phone.
    07-19-2016 12:03 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Go to the App Manager, select Calendar (and probably also Calendar Storage), then Clear Cache/Clear Data.
    07-19-2016 05:51 PM
  3. Darlene Pysyk's Avatar
    The previous suggestions to go to application manager, show system apps, splanner, clear data and cache do not work. I have an S7 edge running Marshmallow 6.0.1.
    any suggestions?
    10-11-2016 03:32 PM
  4. B. Diddy's Avatar
    Welcome to Android Central! Is there a separate app entry called S Planner Data or S Planner Storage? If so, make sure you clear data from there.
    Also, are your calendar events only stored locally on the phone, or are they associated with your Google Calendar account? If the latter, then those events will keep syncing back to the phone from your Google account in the cloud.
    10-12-2016 03:11 AM
  5. Gr12's Avatar
    I do not see the S Planner Data or Storage apps in the Application Manager.
    Running 6.0.1; have tried to clear both contacts and calendar entries with the Clear Data/Clear Cache option, but both keep coming back after appearing to be deleted the first time. Not syncing with anything else (at least that I am aware of!)
    So wondering where or why the apparently deleted entries are coming back from - and how to permanently delete.
    11-09-2016 03:48 PM
  6. mdshiraz's Avatar
    How do I clear my S Planner calendar entires on my Galaxy S7.
    I run Android 6.0.1
    I have tried clearing S Planner Storage > Clear Data. It clears to zero but no success re clearing the S Planner entries
    I don't' sync with any clouds etc..
    There is no Calendar Storage to clear or delete.
    There is no other S Planner storage type apps to clear or delete.
    Samsung Hep desk, says the only way is to delete all the data from the phone and if I do that there's another 1/2 day of my life GONE forever.
    Surely there is a way to fix the multiple duplicate entries Kies has created.
    Thanks for reading this and even more thanks if you can find a solution.
    01-18-2017 05:19 PM
  7. Dngrsone's Avatar
    Have you tried going to Gmail for your phone account and clearing your calendar from there?
    01-18-2017 05:43 PM
  8. jamie001's Avatar
    Hi guys, i had the same problem but managed to fix it so made an account here to share it with you guys
    To delete all calender information (make it completely empty) on Samsung s7, do the following;
    1. Go to applications
    2. Right corner: show system apps
    3. Calendar storage: delete all storage.
    Dngrsone likes this.
    02-19-2017 12:44 AM
  9. Bosbouer's Avatar
    What Jamie said. Plus remove any synchronisation calenders to avoid repopulation.
    02-19-2017 01:03 AM
  1. Galaxy S5 - Screen comes/stays on when charging, what do I do?
    By lnorjones in forum Samsung Galaxy S5
    Last Post: 02-17-2017, 09:27 AM
  2. Replies: 2
    Last Post: 07-22-2016, 09:34 AM
  3. Cycling won't sync from watch to S Health
    By Jenn812 in forum Samsung Gear S2
    Last Post: 07-19-2016, 04:45 PM
  4. Replies: 10
    Last Post: 07-19-2016, 12:40 PM
  5. Replies: 1
    Last Post: 07-19-2016, 12:01 PM
