Save big + get 3 months free! Sign up for ExpressVPN today
  1. Nodnerb's Avatar
    What gives with that? That's ridiculous! I've seen some threads on other forums and such about this but no real solution. Does anyone know how to fix this? I am still getting over 24 hrs on a charge but it should be soooo much better. Could it be my smart watch? Seems like others are having the same issue though without a watch and I didn't have this drain on my htc m9 with the watch.
    07-19-2016 01:37 PM
  2. dpham00's Avatar
    Can you post your battery stats?
    07-19-2016 02:19 PM
  3. Nodnerb's Avatar
    07-19-2016 02:35 PM
  4. dpham00's Avatar
    I would try to use wakelock Detector to identify the cpu wakelock
    07-19-2016 03:23 PM
  5. vag74's Avatar
    Close your location or choose battery save mode for location that drain your battery.
    07-21-2016 03:27 PM
  6. Nodnerb's Avatar
    I think I found the main culprit. It was the always on wifi. Android system is still high, but I've seen a lot of others with it in the same realm as I am now. It's at about 18% these days instead of 50+% just from turning off wifi on while sleeping.
    I didn't expect this to be such an issue since on other phones I've always used wifi keep alive which literally does the same thing with little to no effect on battery life.
    07-26-2016 08:11 AM
  7. chanchan05's Avatar
    More likely that something was using wifi, rather than the wifi being on as the culprit.
    07-26-2016 08:12 AM
  8. Nodnerb's Avatar
    Could be. I have it fairly locked down and not too many apps. But, there hasn't been any increase in data usage and I haven't noticed any adverse effects from turning keep wifi awake off so I'm happy.
    07-26-2016 12:51 PM
  9. Bruins11's Avatar
    You are getting over 2 days? What is wrong with mine?
    Attached Thumbnails Battery stats:Android system 50%, Screen 10%-8736.jpg
    07-29-2016 05:21 AM
  1. Does anyone else prefer big 720p phones for the battery life benefit?
    By jaycrewz in forum General News & Discussion
    Last Post: 07-17-2020, 01:48 AM
  2. Android Neko Easter Egg
    By anon(9072051) in forum Legacy Android & Other OS's
    Last Post: 11-27-2016, 05:43 PM
  3. [FREE ANDROID] Math & Numbers Game
    By aozturkmobile in forum Android Games
    Last Post: 07-27-2016, 10:35 AM
  4. Issues after todays system update, why can't I send emails now?
    By AC Question in forum Samsung Galaxy S7
    Last Post: 07-20-2016, 12:57 AM
