1. AC Question's Avatar
    I have just noticed that the torch (flashlight) that comes with the phone no longer works after the software update. The torch works through a third part app so I know the light works. Is this a known problem and if so is there a fix. Thanks
    07-21-2016 07:32 AM
  2. jeetu4444's Avatar
    Try to restart the phone...or soft reset...if u have mmc card installed...remove it and insert it again...
    posted from Limited red and gold Lumia 950, Beautiful S7 Edge gold or Surface pro 4
    07-21-2016 07:54 AM
  1. Replies: 62
    Last Post: 06-29-2017, 10:07 AM
  2. Why does my phone get hot and drain the battery fast on my S7 Edge?
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 08-16-2016, 10:51 PM
  3. Replies: 1
    Last Post: 07-21-2016, 05:18 PM
  4. How do I turn on master sync on my Galaxy amp Prime?
    By AC Question in forum More Samsung Phones
    Last Post: 07-21-2016, 04:53 AM
  5. Battery drains fast and gets too hot (even after reset)
    By FeleK in forum Samsung Galaxy S7 edge
    Last Post: 07-21-2016, 03:49 AM
