1. KBx315x's Avatar
    I purchased the "fast" Samsung wireless charger and from 10% to 100% it says it going to take almost 4 hours my end piece is a 2,1 amp what did I do wrong??
    07-22-2016 01:08 AM
  2. chanchan05's Avatar
    Are you using the Samsung fast charger plug? If you aren't, it won't work.
    07-22-2016 02:00 AM
  3. YankInDaSouth's Avatar
    Also, be sure to enable fast wireless charging under the battery settings
    07-22-2016 04:41 AM
  4. shook187's Avatar
    How about a case? Are you using one what kind.? is it really thick?
    07-22-2016 05:17 AM
  5. KBx315x's Avatar
    No case and no samsung fast charger. I also dont have the option for fast wireless charging I'm on Verizon.
    07-22-2016 11:34 AM
  6. areyes163's Avatar
    I have the option for fast wireless charging on my Verizon S7 edge
    07-22-2016 03:31 PM
  7. chanchan05's Avatar
    The Samsung fast charger comes out of the box. The option SHOULD be there.. Otherwise I'd question the phone's authenticity.
    07-22-2016 04:11 PM
  8. Bruins11's Avatar
    My wireless"fast" charger is anything but fast. When I need it charged quickly I just use the cord.
    07-29-2016 05:24 AM
  9. cwbcpa's Avatar
    That option just allows you to turn it off. I have Verizon as well and don't have that. Fast charging is enabled by default. Make sure you are using the fast charging wall charger with the fast charging pad.
    07-29-2016 06:28 AM
  1. Replies: 1
    Last Post: 07-27-2016, 08:02 AM
  2. How do I remove the USERBUG from my screen?
    By oditius in forum LG G Pad 7.0
    Last Post: 07-26-2016, 05:57 AM
  3. Replies: 1
    Last Post: 07-22-2016, 01:11 AM
  4. how do i move photos to my sim card
    Last Post: 07-21-2016, 08:31 PM
  5. how do i screen shot when gaming on my galaxy s5
    Last Post: 07-21-2016, 06:56 PM
