1. piannetta's Avatar
    Hi there, I'm finding that when I dial a number in the stock dialler, there's a delay for anywhere up to 20-30 seconds before it will actually ring the number. I tap on the dial button, nothing happens. I tap several times and eventually it will dial. Does anyone know what could be causing this or help me diagnose it please?
    Cheers,
    Pete
    07-23-2016 06:16 PM
  2. B. Diddy's Avatar
    Does this happen regardless of your cell signal strength?
    Try wiping the cache partition: https://support.t-mobile.com/docs/DOC-25076
    07-23-2016 11:09 PM
  3. piannetta's Avatar
    No, seems to happen all the time regardless of signal strength
    07-24-2016 03:25 PM
  4. B. Diddy's Avatar
    If the cache wipe does nothing, then see if it persists in Safe Mode: https://support.t-mobile.com/docs/DOC-25053
    07-24-2016 09:41 PM
  1. How do you unlock an S7 when it just freezes up?
    Last Post: 08-04-2016, 04:47 PM
  2. When is lg g4 getting 6.0.1 update??
    Last Post: 07-24-2016, 08:03 PM
  3. Why is memory full when everything is on my SD card?
    Last Post: 07-23-2016, 09:17 PM
  4. Replies: 0
    Last Post: 07-23-2016, 05:30 PM
  5. Replies: 0
    Last Post: 07-23-2016, 12:41 PM
