1. johnnyshinta's Avatar
    I know there 1001 choices for sms. I like the aforementioned apps because they can do split screen and pop out. Anyone use either of these and if so which?
    07-24-2016 04:13 PM
  2. FaTROBoT97's Avatar
    Ive been using VZ Messages for a couple months now. It works fine. Opens pretty fast and some options in there. I haven't used the default app though so I can't give you any feedback.
    07-24-2016 04:24 PM
  3. underway99's Avatar
    I use Verizon Messages. It seems to have most of the features than the big names have, and I can keep up with SMS on my PC with Verizon's Message+ desktop app.
    07-24-2016 04:26 PM
  4. johnnyshinta's Avatar
    Have you guys been able to get the message to preview in the people tab. Like when some from my people tab texts me I get a little colored tab that I can pull out to read the text (when using the stock app) and call message or email. With vz messages I don't see the preview.
    07-24-2016 04:42 PM
  5. FaTROBoT97's Avatar
    I don't see the preview if your talking about pulling the tabs out -- but if i pull it out it loads to VZ Messages
    07-24-2016 05:07 PM
  6. areyes163's Avatar
    I like both for different reasons. I like the Verizon messages because I can send Gifs easily. With the stock app I cannot because of the text size limits.
    07-24-2016 05:20 PM
  7. tracypagedotnet's Avatar
    I think message+ is superior to the stock app, but it isn't 100% compatible across the board. For instance, I can't use it with my gear plus neo... And reading texts without pulling out my phone is basically the only reason to have a smart watch.
    07-24-2016 10:59 PM
  8. afh3's Avatar
    I use Verizon Message+ as the default SMS client, but have selected the Samsung messaging app as the one for notifications on my Gear S2 (Bluetooth). Not sure why it works, but this allows me to read my incoming messages on the watch and respond to them as well without touching my phone. The messages continue to synchronize with the Verizon app, and there is no issue that I've discovered so far.
    This is reproducible, as my wife's works the same way. I know it isn't the same watch as you specified, but it may help others in a similar situation.
    tracypagedotnet likes this.
    07-25-2016 08:02 AM
  9. MizWylie's Avatar
    Neither! I use Textra SMS!
    Rebel.
    Posted from the S7E Chrome™ on Big Red
    johnnyshinta and speedtrap63 like this.
    07-25-2016 11:33 AM
  10. speedtrap63's Avatar
    Rebel.
    Seconded!
    johnnyshinta likes this.
    07-26-2016 04:13 PM
  1. What Computer/surface should i get to go with my new samsung note 7?
    By that biasaed apple fanboy in forum Samsung Galaxy Note 7
    Last Post: 07-30-2016, 12:25 AM
  2. Verizon Network Extender Problems
    By jimbo1mcm in forum Nexus 6P
    Last Post: 07-25-2016, 12:11 AM
  3. Will the note have better specs then the s7 edge or should I just buy the s7 edge?
    Last Post: 07-24-2016, 04:56 PM
  4. htc one m8s uptade or reset to factory problems
    Last Post: 07-24-2016, 03:54 PM
  5. Samsung S6 Edge - missing icon
    By 40-40j in forum Ask a Question
    Last Post: 07-24-2016, 02:17 PM
