1. hokie_prof's Avatar
    I use to have touch sounds when I used the keyboard on my phone. It At some point the audio vanished. I can't figure out how to restore it.
    I am using themes from the Samsung Theme Store, but I haven't changed launchers. As far as I know, I'm using the Samsung keyboard.
    Any suggestions on how I can get keyboard sound back?
    07-24-2016 04:22 PM
  2. B. Diddy's Avatar
    If you go to Settings>Language & Input and select Samsung Keyboard, can you find an option there for Sound on Keypress? If so, is it turned on?
    07-24-2016 10:07 PM
  3. tanson1011's Avatar
    The tactile feedback on the Google keyboard seems to just vanish as well. Even thought the settings show tactile feedback is on. Happened twice so far. Have to switch to a different keyboard then switch back to have it work.
    07-25-2016 10:03 PM
  1. HTC10 annoying notification sounds
    Last Post: 07-24-2016, 08:54 PM
  2. Why is my equalizer missing?
    Last Post: 07-24-2016, 04:09 PM
  3. Samsung S6 Edge - missing icon
    By 40-40j in forum Ask a Question
    Last Post: 07-24-2016, 02:17 PM
  4. Replies: 0
    Last Post: 07-24-2016, 12:50 PM
  5. Wrong keyboard...
    Last Post: 07-24-2016, 12:08 PM
