1. iammuddii's Avatar
    I have samsung s7 edge regular edition (non-rooted) , I tired so many time to apply batman theme on my mobile,
    I install batman theme and apply it, and disable theme store and theme center by package disabler pro,
    but just after 5 or 6 mins, batman theme trail ended and default theme apply automatically.
    what should i supposed to do now??
    07-26-2016 02:01 AM
  2. NexusGirlX's Avatar
    I would stop disabling the theme store and theme center and then I bet the theme stays on the phone.
    07-26-2016 02:06 AM
  3. BruceFlea478's Avatar
    Make sure you clear the cache of the two applications you disabled in the package disabler after you disabled them. Should work like a charm afterwards.
    Posted via the Android Central
    07-26-2016 04:24 AM
  4. jeetu4444's Avatar
    Yes make sure u clear the cache of both apps and just press home button to exit package disabler then remove it from recent apps
    posted from Limited red and gold Lumia 950, Beautiful S7 Edge gold or Surface pro 4
    07-26-2016 05:41 AM
  5. Tower72's Avatar
    I have used many of the ones off XDA (Batman, RoboCop, Civil War etc) and I did the same steps you did , and they stick for me when I disable the store and the themes
    07-26-2016 11:40 PM
  6. areyes163's Avatar
    Did you pay for the theme or were you using the trial. The trial only lasts for 5 minutes and then it reverts back to the default theme.
    KPMcClave likes this.
    07-27-2016 09:13 PM
  7. Tower72's Avatar
    That they do but when you disable the 2 packages, it doesnt expire (mine doesnt but this is how it is supposed to work)
    07-27-2016 11:47 PM
  8. jeetu4444's Avatar
    Loving the batman theme on my s7 edge ...really kool...no need to buy batman edition s7 edge 😜
    07-28-2016 08:28 AM
  9. Rahim Bhanji's Avatar
    Hi. Am not so techy. How do I cleat the cache of the 2 apps
    08-03-2016 04:34 AM
  10. jeetu4444's Avatar
    Press and hold on them and it will show options of disable and clear...
    1st disable then press clear
    08-03-2016 07:52 AM
  11. YMarkY's Avatar
    Are people disabling the theme store after applying a theme to circumvent the trial time period? If so, that's weak. Pay a few bucks for a developer's time.
    08-03-2016 10:14 AM
  12. NexusGirlX's Avatar
    I know on XDA, there is a Batman apk being offered there that people can install on rooted phones. This might be what some people in here are referring to.
    08-03-2016 10:24 AM
  13. jeetu4444's Avatar
    These themes are not available on the store
    08-04-2016 10:33 AM
  14. kushal gera's Avatar
    package disabler pro not working
    now it cant hold the batman theme for more than 5 minutes
    any solution guys ?
    08-30-2016 12:54 PM
  15. kushal gera's Avatar
    better it would be if the prob. is solved without rooting**
    08-30-2016 12:56 PM
  16. jeetu4444's Avatar
    Read my earlier comment
    Posted via Limited Edition Lumia 950 with Mozo Case or Beautiful Gold S7 Edge or Surface pro 4 or Lumia 1020 or motoe or iphone 5s
    08-30-2016 03:37 PM
  1. S7 Edge randomly starts playing music
    Last Post: 08-01-2016, 07:35 AM
  2. Replies: 1
    Last Post: 08-01-2016, 05:02 AM
  3. samsung galaxy j7
    By Sudu nirosha in forum Samsung Galaxy J Series
    Last Post: 07-26-2016, 01:08 PM
  4. I can't change my samsung password.
    Last Post: 07-26-2016, 01:18 AM
  5. Replies: 0
    Last Post: 07-26-2016, 12:43 AM
