1. tracypagedotnet's Avatar
    Notice how the image distorts near the edge of the frame, making my hand appear as large as my head? I had the same issue with my Note 4, but don't remember it on any of my iPhones...
    Is it a Samsung issue or Android or what?
    07-27-2016 10:44 AM
  2. SpookDroid's Avatar
    If you're taking this with the selfie camera, it's not an Android or iOS issue: It's the lens. It has a slight fish-eye effect to capture a wider angle, causing stuff around the edges to distort a little. You shouldn't, however, see that effect (unless you apply that filter) in your rear-camera pictures.
    tracypagedotnet likes this.
    07-27-2016 12:31 PM
  3. shook187's Avatar
    You sir have a giant hand or small head
    07-27-2016 12:52 PM
  1. Camera causes send button to not work on S6
    By amwd1980 in forum Samsung Galaxy S6
    Last Post: 08-07-2016, 08:50 AM
  2. WiFi issues
    By pedronev925 in forum TAG Heuer Connected
    Last Post: 07-27-2016, 03:45 PM
  3. when i dwnld some data my phn show wifi issue so plzz help .
    Last Post: 07-27-2016, 07:19 AM
  4. Replies: 3
    Last Post: 07-27-2016, 05:46 AM
  5. At&t Galaxy s7 with straight talk mobile data issues
    Last Post: 07-26-2016, 11:32 PM
