1. surfnmassage's Avatar
    I bought a 128 gig micro sd card and it worked fine for 2 weeks. Then all of a sudden today my s7 edge is not reading it anymore. When I go to storage I can't even see it listed. Any help would be greatly appreciated. Thanks.
    07-27-2016 01:20 PM
  2. SpookDroid's Avatar
    Have you tried removing it and putting it back in? What about if you try to use it in a different device or if you try a different card in your phone? Maybe the card is damaged...
    tube517 likes this.
    07-27-2016 02:05 PM
  3. tube517's Avatar
    Also, check if it is a legit card.
    What is the brand name and where did you buy it?
    Use the free app, SD Insight.
    07-27-2016 02:17 PM
  4. fuzio1963's Avatar
    Can your comp read it? If not -
    Buy a new card.
    07-28-2016 02:19 PM
  5. H2o's Avatar
    Mine did the same. Worked fine after the update for a day. Now it's dead. Computer won't even recognize it
    07-28-2016 07:23 PM
  6. NexusGirlX's Avatar
    Mine just did the same thing. It's a genuine Samsung card. My computer shows everything is still there, the phone just won't show anything on the card. The MyFiles app showed they were still as well.
    I simply copied everything from the SD card to my computer, formatted the card and then copied everything back onto the card. This time, everything showed back up on the phone. Not sure what happened.
    07-29-2016 08:15 AM
  1. Replies: 0
    Last Post: 07-27-2016, 11:23 AM
  2. Why won't my earphones work in My Galaxy s6
    Last Post: 07-27-2016, 11:10 AM
  3. Replies: 0
    Last Post: 07-27-2016, 10:59 AM
  4. I cant get android auto to work on my 2016 Chevy Colorado
    Last Post: 07-27-2016, 09:57 AM
  5. app not installed on usb storeg or sd card
    Last Post: 07-27-2016, 08:57 AM
