1. FreedomLife's Avatar
    When I bought the phone, Immediately, I activate on the first time, Then dropped me an update version of the phone.
    But after factory reset, Not showing update version...
    do After factory reset, Updates version need to get off again?
    thank you
    07-28-2016 08:05 PM
  2. srkmagnus's Avatar
    thank you
    I'm not fully following what you are asking. However, if you accept an update then proceed to factory reset after the update completes then you will still be on the most current software update. Go into Settings > About Phone. Let us know what software version you are on.
    FreedomLife likes this.
    07-28-2016 08:32 PM
  3. chanchan05's Avatar
    Factory reset does not remove OS updates.
    07-28-2016 09:04 PM
  4. FreedomLife's Avatar
    My friend, if reset in Windows, for example.
    So, after reset, Must install all updates again
    On Android, After factory reset, Don't need to do that?
    The system updates already installed on the phone?
    07-29-2016 05:10 AM
  5. FreedomLife's Avatar
    Are you sure friend?
    I remember that.... On my LG g2, After reset, Need to reinstall, Again
    But maybe I'm wrong ...
    07-29-2016 05:13 AM
  6. chanchan05's Avatar
    Yes I'm sure. Same way for any Android phone.
    srkmagnus and FreedomLife like this.
    07-29-2016 06:17 AM
  7. FreedomLife's Avatar
    ok thank you
    07-29-2016 07:23 AM
  8. srkmagnus's Avatar
    Yes, as mentioned a factory reset will not remove the software version. It only resets the phone to stock on the same OS.
    07-30-2016 05:29 PM
  9. FreedomLife's Avatar
    And how do I check what current version for galaxy s7 edge ?
    07-30-2016 05:33 PM
  10. t11rmh's Avatar
    Got into settings then about device then software info.
    Posted via the Android Central App via a kicking Gold Galaxy S7 Edge.
    07-30-2016 06:12 PM
  11. FreedomLife's Avatar
    yes, but, How do I know what new version of the Samsung has released?
    07-30-2016 07:23 PM
  12. Iva_LadyDiCaprio98's Avatar
    You'll go to settings and about device and it will tell you the latest software you have. It should have the July security patch with Android 6.0.1
    07-30-2016 07:41 PM
  13. FreedomLife's Avatar
    Dear friend
    I want to know what last software version , Company Samsung published to galaxy s7 edge
    What is the way?
    07-31-2016 04:31 AM
  14. chanchan05's Avatar
    Dear friend
    What is the way?
    Would it even matter? Even if Samsung published a newer update than what you have? You can't get it if it's not made available by your carrier or for your region specific model.
    07-31-2016 05:20 AM
  15. FreedomLife's Avatar
    General knowledge
    Also I know what I'm going to receive ...
    07-31-2016 11:14 AM
  16. Iva_LadyDiCaprio98's Avatar
    Dear friend
    What is the way?
    I'm not sure what you mean. The software that is on your phone is the latest available to Samsung. Unless you mean Nougat which will not be released this year so if that's not what you're referring to, then I am at a loss at what you're asking for.
    07-31-2016 11:22 AM
  17. pjwk81's Avatar
    Sammobile will show the latest released build for your version and region.
    07-31-2016 02:21 PM
  18. FreedomLife's Avatar
    My friend what is this site?
    And how i looking for latest version in my area?
    Iva_LadyDiCaprio98, I just want to know about recent versions I don't understand well English..
    I don't always explain myself right, sorry.
    08-01-2016 01:17 PM
  1. Replies: 3
    Last Post: 08-01-2016, 07:44 PM
  2. how do I factory hard reset my lg sunrise from straight talk?
    Last Post: 07-28-2016, 09:30 PM
  3. Why wont S4 mobile hotspot connect to pc after update?
    Last Post: 07-28-2016, 05:53 PM
  4. How to Update a Rooted HTC One M8 to Marshmallow (Currently Kit Kat)
    By Andy_Sixx in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 07-28-2016, 05:49 PM
  5. Replies: 0
    Last Post: 07-28-2016, 04:14 PM
