Shop HP’s Memorial Day Sale:Save up to 61% on PCs and more!
  1. tracypagedotnet's Avatar
    Starting to play around with customizing my interface with Nova and the default themes as well.
    My "problem" is when I change a theme, it will not change the icon pack, presumably because Nova is controlling that. However, when I go to change that in the Nova setting, the icon pack(s) for the default theme manager are not in the same location where theme packs from the playstore are stored. Meaning I cannot use the default theme icons on any theme....is there a solution? Maybe I need a different launcher?
    07-28-2016 10:12 PM
  2. MrsWaffles's Avatar
    The icons can only be used in TouchWiz. Other launchers won't see them.
    tracypagedotnet likes this.
    07-29-2016 02:29 AM
  3. pjwk81's Avatar
    Yeah I found that too. Main reason that this is the first phone in years I don't use Nova on.
    07-29-2016 04:44 AM
  4. mark McWilliams1's Avatar
    I have a nexus 6p and use nova prime with ruggon icons and love it
    Sergiusz Jasper likes this.
    07-29-2016 05:04 AM
  5. tracypagedotnet's Avatar
    Yeah, I guess you can't have your cake and eat it too. Is Nova still the top of the food chain?
    07-29-2016 05:24 PM
  6. TJA3500's Avatar
    There are some stock looking icon packs in the Play store.
    I also would like a way to use icons from the theme I have but can't find a way.
    https://play.google.com/store/apps/d...f.alonso.icon5
    07-29-2016 08:33 PM
  7. RocketFoot's Avatar
    I am trying out Awesome Icons right now and seems to be OK. It creates shortcuts using icons from any source so you can use the stock icons as well!
    https://play.google.com/store/apps/d...code.shortcuts
    07-30-2016 10:01 AM
  8. tracypagedotnet's Avatar
    Still not happy with this combination....
    Any idea why the themes on XDA won't work with the theme store? I ask because after the last update, they're no longer an option either as you no longer have access to one of the features that must be disabled.
    07-30-2016 05:02 PM
  1. S6 Circles around many of my app icons. Icon inside is smaller
    By AC Question in forum Samsung Galaxy S6
    Last Post: 02-20-2018, 03:12 PM
  2. Samsung Galaxy S5 send icon will not send text messages
    Last Post: 08-01-2016, 08:08 AM
  3. White corners are happening on our app icons
    Last Post: 08-01-2016, 07:54 AM
  4. Replies: 1
    Last Post: 07-28-2016, 04:16 PM
  5. Replies: 1
    Last Post: 07-28-2016, 05:06 AM
