1. tracypagedotnet's Avatar
    Are there customizable keyboards or a way that I can totally eliminate the period all together?
    I absolutely HATE this phone because of the location of the period on the keyboard.
    Any and all REAL solutions to the problem are appreciated!!!
    07-29-2016 10:03 AM
  2. cwbcpa's Avatar
    Just so I understand the problem. You don't like that the period is to the right of the space bar? There are a lot if keyboards in the play store. Many are customizable but I believe the period is in the same place on any keyboard I've ever used. Swift key is a very customizable keyboard but I'm not sure about moving the period. I'll look and see.
    07-29-2016 10:08 AM
  3. chanchan05's Avatar
    I've tried several of the most popular keyboards, and all of them have the period on the right of the keyboard.
    I don't think there are any solutions because this isn't an actual problem that needs to be addressed in order for the phone to keep working, but rather just a preference on your part. You can try a different keyboard still though. Key sizes and spacings are different, so it may help you.
    07-29-2016 10:45 AM
  4. tracypagedotnet's Avatar
    that's correct, the placement of the period on the keyboard cause me to hit it rather than the space bar, and in a hurry, I can easily have 3-4 periods in one sentence.
    I would rather have no punctuation at all...not even kidding :/
    07-29-2016 10:59 AM
  5. cwbcpa's Avatar
    Ok but it's in the same place on every keyboard I've ever seen. Have you seen it different on another phone/keyboard?
    07-29-2016 11:10 AM
  6. tracypagedotnet's Avatar
    I am assuming it's a size issues as I did not have this problem on the Note 4
    07-29-2016 11:11 AM
  7. tracypagedotnet's Avatar
    This. Is what a typical response. Might looks like from me without editing.
    Edit: I am using Swiftkey, which did help a bit by resizing the keyboard, but it's not enough I guess
    07-29-2016 11:16 AM
  8. cwbcpa's Avatar
    Interesting. I have been a Note user as well, Note 2, 3, 4 & 5 prior to the S7E and have not noticed any more than any other phone. I still don't care for on screen keyboards in general so I can understand your frustration.
    07-29-2016 12:56 PM
  9. pjwk81's Avatar
    I hate that too because most.sentences.come.out.like.this. for me.
    The stock keyboard on an LG used to let you move the buttons around so I could offset the space towards the right but I've never seen another that allows it.
    tracypagedotnet likes this.
    07-29-2016 05:36 PM
  10. kjung7's Avatar
    Making the stock keyboard a little taller has helped me with this dreaded. Problem. It. Was. So. Annoying. Haha
    cwbcpa likes this.
    07-31-2016 07:04 PM
  11. anon(94650)'s Avatar
    I use Thumb Keyboard by Beansoft. Very customizable, including a split keyboard and being able to increase the height of just the row with the space key.
    08-02-2016 02:02 AM
  12. MikeRotch76's Avatar
    I still think BlackBerry makes the best keyboard for Android. I might be a little bit biased though coming from a Z30, and then a Priv to the S7E.
    Sean Fanelli likes this.
    08-02-2016 11:34 AM
  13. Sean Fanelli's Avatar
    Easily the best, maybe bb will bring that keyboard to other android devices
    08-02-2016 01:07 PM
  14. kjung7's Avatar
    Here's a thread that goes over installing Blackberry apps on non-related Android phones. The keyboard apparently works, but I haven't tried it myself.
    https://r.tapatalk.com/shareLink?url...3&share_type=t
    Run all Blackberry Priv apps on any Android device [no root required]
    08-02-2016 03:10 PM
  1. Google Keyboard Settings Crash
    Last Post: 04-05-2019, 02:16 PM
  2. Keyboard quits unexpectedly
    By Ile Spasev in forum Alcatel Android Phones
    Last Post: 08-05-2016, 04:42 AM
  3. Replies: 1
    Last Post: 07-28-2016, 05:16 PM
  4. Galaxy S7 Keyboard Cover Case Question
    By Sun Hyung Hong in forum Samsung Galaxy S7
    Last Post: 07-27-2016, 02:11 PM
  5. Replies: 0
    Last Post: 07-26-2016, 05:31 PM
