1. AC Question's Avatar
    So I received my new S7 edge in the post yesterday and as I was setting it up in my half lit living room I accidentally poked the microphone slot with the sim card tool, I didn't feel anything poke through or break, but I was wondering if anyone could confirm a couple of things for me. Is the microphone not directly below the hole, and slightly to the side and in an 'L' shape? I've read this on a couple of other posts and it was mentioned by a few people, also will this have damaged the water resistance? Just slightly anxious that I've damaged the phone after having it for 5 minutes.
    Thank You
    07-30-2016 04:48 AM
  2. dpham00's Avatar
    Well it could have damaged the water resistance
    07-30-2016 02:58 PM
  3. bullittmustang's Avatar
    Thank You
    I did the same thing when I first got my phone back in April. It has been fine so far. I also read that it is not straight down it is an L shape. You can test the function of the upper microphone by using the voice recorder app and putting it in interview mode.
    08-01-2016 06:36 PM
  1. My Galaxy S7 hasnt slowed down yet, how about yours?
    By yogosans14 in forum Samsung Galaxy S7
    Last Post: 08-02-2016, 04:54 AM
  2. how do I use wifi to copy files from PC to SD card inside the S7 edge?
    By badkitties in forum Samsung Galaxy S7 edge
    Last Post: 07-31-2016, 05:32 PM
  3. Samsung s7 overheated and melted charger
    By AC Question in forum Samsung Galaxy S7
    Last Post: 07-30-2016, 03:01 PM
  4. How to root or where to find instructions on how to root Samsung Galaxy s6 edge
    By AC Question in forum Samsung Galaxy S6 edge Rooting, ROMs, & Hacks
    Last Post: 07-30-2016, 02:59 PM
  5. ATT Galaxy S7 July Security / Kernel Causing Problems
    By jitter77 in forum Ask a Question
    Last Post: 07-29-2016, 09:11 PM
