1. JOHNGAETANO's Avatar
    Was going to pick up a 7 edge tomorrow, but should I wait to see what the Note 7 is all about? I've had notes before. Like the size, but dont find myself using the pen.
    07-30-2016 08:29 PM
  2. nahoku's Avatar
    If you don't need the S Pen, then either would do. Just a few more days before official announcement so if it were me, I would wait.
    07-30-2016 08:45 PM
  3. tracypagedotnet's Avatar
    I personally liked my Note 4 over the S7E, so my vote is wait for the N7
    07-30-2016 09:32 PM
  4. LdotAdot13's Avatar
    From what the leaks have suggests the note 7 will have a bigger screen and a smaller battery. Seems like the S7 Edge would be the better pick.
    Sent from Sir Cletus Sexy IV.
    (S7 Edge Titanium)
    sqa4life and tanker8764 like this.
    07-31-2016 10:25 AM
  5. areyes163's Avatar
    Being is that the official announcement is in a couple of days I would definitely wait until then. Can't hurt and that way you won't kick yourself if it turns out you wanted the Note instead.
    07-31-2016 11:17 AM
  6. badMojo69's Avatar
    Might be a wash if there is a new CPU that is more energy efficient, making a larger battery a non issue.
    I just keep a battery case in my car for my Edge7 in case I'm going to be out really late.
    07-31-2016 01:39 PM
  7. Almeuit's Avatar
    As some said.. depends on S-Pen use. I use mine so the Note is worth it.
    07-31-2016 01:42 PM
  1. How do i turn off screen overlay on my s7 edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 10-09-2016, 12:23 PM
  2. wifi and mobile data widget or something?
    By Nastybloodlust in forum Nexus 5X
    Last Post: 07-31-2016, 01:40 PM
  3. Is iot a real software update or a virus???
    By Yair Pinyan in forum Samsung Galaxy Note 5
    Last Post: 07-31-2016, 06:21 AM
  4. Replies: 1
    Last Post: 07-30-2016, 11:49 PM
  5. Replies: 1
    Last Post: 07-30-2016, 11:43 PM
