1. tracypagedotnet's Avatar
    Rooting my G935V as we speak....
    Installing Xposed & optimizing apps......so I have time to kill.
    Wish me luck
    07-30-2016 11:18 PM
  2. tracypagedotnet's Avatar
    root was simply enough but I cannot get any of the XDA themes to stick
    07-31-2016 01:44 AM
  3. tracypagedotnet's Avatar
    w00t...got it AND the XDA themes working now
    My nerd is so hard right now....
    07-31-2016 02:44 AM
  4. Hal Jordan3's Avatar
    I just rooted mine too using these instructions:
    How To Root ANY Galaxy S7 or S7 Edge!
    My question now is how do I install Xposed? I can't see how to Reboot the phone into a custom booter?? Holding down volume down and power? IT doesn't boot into the custom boot loader.
    Please let me know how you got the next step? I'm used to rooting using ODIN and TWRP, but this didn't use TWRP, this is different...
    Thanks in advance.
    08-10-2016 09:23 PM
  5. tracypagedotnet's Avatar
    Verizon Root Guide (Knox still good) | Verizon Samsung Galaxy S7 Edge
    You can now install Xposed via Flashfire. Unfortunately, TWRP does not work on this method, so, DO NOT TRY, there is a chance that you can Brick your phone from doing that.
    08-11-2016 03:37 AM
  6. tracypagedotnet's Avatar
    Wish I could be of more assistance, but this is the first time I've rooted an Android device and I did not experiment at all. I followed the instructions to the letter, then upon noticing a significant reduction in performance, reflashed a stock ROM
    08-11-2016 03:43 AM
  7. NexusGirlX's Avatar
    I have a T-Mobile S7 Edge and went back to stock after two weeks for the very same reasons. I loved being rooted but having a fast phone with great battery life is more important to me.
    tracypagedotnet likes this.
    08-11-2016 05:39 AM
  1. Replies: 8
    Last Post: 04-27-2017, 02:46 PM
  2. What is error code 0x116be - kingo root?
    Last Post: 07-30-2016, 10:19 PM
  3. Tried to Root Galaxy Tab s2 now wifi won't connect
    Last Post: 07-30-2016, 05:00 PM
  4. How to root or where to find instructions on how to root Samsung Galaxy s6 edge
    By AC Question in forum Samsung Galaxy S6 edge Rooting, ROMs, & Hacks
    Last Post: 07-30-2016, 02:59 PM
  5. Replies: 1
