1. John Hosten's Avatar
    After struggling with my GS5 for the past year due to:
    -inability to clear storage due to mysterious Miscellaneous files taking up 2GB though I clear most and the top one is 49 MB
    -pictures taking 10 seconds to snap
    -phone freezing
    -fast battery drain
    -having to re-move my apps to the SD card every time there is an update. One at a time. This is the most frustrating thing about this device (hope it isn't so on the Edge)
    I have searched and addressed what I can but I'm done with this phone and am most likely getting the Edge 7 (had a galaxy phone since the first one - Captivate)
    That being said, I was wondering if it makes a difference where I purchase. I'm ATT and I'm new to the Next plan, which is what they all are. And I'm eligible for an upgrade obviously. Target, Best Buy, ATT store...does it make a difference? I know they each have perks from time to time...but that notwithstanding, I'm guessing my bill will all be the same depending on which Next plan I choose...that's a constant, right?
    Any leanings towards any store (or even online through ATT for that matter) amongst you guys? Or...
    does it not matter.
    I know I'm asking a pretty obvious question but wanted to make sure I covered my bases. I'm not sure which Next plan to do, if I can swing a down payment, that'd be better. Not sure if that varies as 'perks' either between the stores.
    Thanks in advance,
    John
    07-31-2016 02:37 PM
  2. Iva_LadyDiCaprio98's Avatar
    I upgraded to my s7 edge by using the AT&T Next program. I'm paying about $26 per month for the device on top of my bill. It's been 4 months since I've had the phone so far. I have about 2 years to pay it off unless I choose to pay it all off in one go which I can and will once I bring the cost of the phone down by at least half.
    07-31-2016 02:57 PM
  3. John Hosten's Avatar
    Thanks Iva! Did you buy from ATT directly or elsewhere?
    07-31-2016 04:20 PM
  1. Replies: 2
    Last Post: 07-31-2016, 02:58 PM
  2. How do I send text messages to email
    Last Post: 07-31-2016, 02:48 PM
  3. Replies: 1
    Last Post: 07-31-2016, 02:35 PM
  4. Replies: 1
    Last Post: 07-31-2016, 02:10 PM
  5. How do I get my s7 to connect to my tv?
    Last Post: 07-31-2016, 02:00 PM
