1. that biasaed apple fanboy's Avatar
    I was planning on upgrading from an iPhone 6s plus to a note 7 but I felt after thinking about it what am I going to gain?
    The s pen I would most likely not use
    The processor will be the same if not slightly upgraded
    the ram will be increased usually is on a note and some software twerks.
    I also didn't like the size of my iPhone 6s plus I was always getting angry because It was so big my mum would often have to carry it for me if we went out in her purse because I couldn't fit it in my jean pockets and if I did it gave girls the wrong impression lol
    What do you guys think about my decision? Do you feel I made the right one? The s series is the flagship series where the note is more aimed at professionals but I'm interested to hear your thoughts.
    shanghaichica likes this.
    08-01-2016 05:40 PM
  2. shook187's Avatar
    It comes down to 3 things, size, S-spen and price... if two of those three things mean anything to you, then that should sway you to pick one over the other
    08-01-2016 05:50 PM
  3. Almeuit's Avatar
    If you don't think you would use the S-Pen then you're good. I use it a lot so I like the Note. I did have an S7 Edge for awhile though and it definitely isn't a bad device.
    08-01-2016 05:51 PM
  4. ajb1965's Avatar
    Edge is one of the best Android phones I've ever had. I usually have complaints after a month with a phone and I've had zero with this one...
    JHStewart1023 likes this.
    08-01-2016 06:36 PM
  5. cwbcpa's Avatar
    As big as the Note is, it is still easier to hold than the iPhone 6s Plus. The Note 5 is great in the hand but the S7 Edge is even better.
    As was mentioned, it really comes down to that S-Pen. The Note will also have a slightly larger screen and also have more internal storage I believe. The biggest difference is that S-Pen though.
    I have been a Note fan since the Note 2 but I'm not sure I'm jumping from the S7E yet. We will see how it plays out. The S7E is a great phone.
    njshoremom4gurlz likes this.
    08-01-2016 09:42 PM
  6. badMojo69's Avatar
    I've been saving all year to buy the N7 outright and give my S7E to my wife.
    08-01-2016 10:44 PM
  7. RocketFoot's Avatar
    I went with the S7 Edge because of the battery...3600mAh is awesome! I can now go from 4:30am to 10pm and still have 30%-50% left! I think the Note 7 has the 3000 mAh.
    08-02-2016 07:37 AM
  8. chanchan05's Avatar
    It will get 3500mah
    08-02-2016 07:59 AM
  9. Sean Fanelli's Avatar
    Food choice comming from iphone. Authough im confused because they both have 5.5 inch screens. The edge does loose the bezels so i guess overall the phone is a little smaller?
    08-02-2016 08:32 AM
  10. chanchan05's Avatar
    Then phone is a LOT smaller. Apples have such huge bezels. The iPhone Plus is if I remember correctly as big as a Note 5 with a 5.7inch screen, if not even bigger. iPhones are bigger than same screen sized Android phones.
    08-02-2016 08:58 AM
  11. shanghaichica's Avatar
    I've owned 3 notes and after the novelty wore off I didn't use the S-pen.
    I've been using the 6S plus/ 6 plus for 2 years and find the 5.5 inch screen size to be the sweet spot.
    I have a 3 month old son and being able to use a phone one handed has become important to me. I still need a large display but in a compact package. All of this makes the S7 edge the phone for me.
    I wouldn't use the iris scanner. It's too gimmicky for me. I never used face unlock on the previous android phones. Not even once. I'd much rather use the fingerprint scanner.
    08-02-2016 03:06 PM
  12. kjung7's Avatar
    A lot of people using the iris scanner on the Surface Pro 4s say they love it. I think iris scanners have the potential to be much quicker than fingerprint readers.
    08-02-2016 03:17 PM
  13. tofu.'s Avatar
    i see the iris scanner as a backup.
    Wearing gloves? iris scanner
    Fingers wet? iris scanner
    08-02-2016 11:11 PM
  14. johnmcc0710's Avatar
    I just got the Edge, I had an S7 which I liked but the more I saw the edge and played with it the more I wanted it. I have it for 2 days and love it so far. I had a Nexus 6P which I did not like as much due to size and texts in my car never worked.
    08-03-2016 10:12 PM
  15. shanghaichica's Avatar
    But you will still need to take off your gloves to navigate the phone once it's unlocked.
    Posted from my pink gold S7 edge
    08-04-2016 12:13 AM
  16. Gator352's Avatar
    Who is iris and why do I have to scanher?
    Alan Sims likes this.
    08-06-2016 10:13 PM
  17. Roman Akert's Avatar
    The iris scanner is a software implementation. Surely it could easily be rolled out for the 7E with a future update.
    08-07-2016 03:57 AM
  18. shook187's Avatar
    It's hardware.. There's a iris IR on the front.
    chanchan05 likes this.
    08-07-2016 04:29 AM
  1. Replies: 2
    Last Post: 09-13-2016, 05:05 PM
  2. Issue opening pdf files on Samsung Galaxy S6 edge
    By Vickylouiseuk in forum Android 6.0 Marshmallow
    Last Post: 08-02-2016, 05:28 PM
  3. The Note 7 is 100% guaranteed to have a MicroSD card slot, right?
    By badkitties in forum Samsung Galaxy Note 7
    Last Post: 08-02-2016, 05:03 PM
  4. Replies: 1
    Last Post: 08-01-2016, 03:49 PM
  5. Macbook air nor PC will recognize my Galaxy Note 3
    Last Post: 08-01-2016, 03:44 PM
