1. Sean Fanelli's Avatar
    Just bought this phone anout 2 days ago, and the battery is draining extremely fast. I know this happens with sime phones, do i just need to give it a week? Im losong almost 10% a half hour
    08-02-2016 07:34 AM
  2. Doc Marten's Avatar
    Mine did the same for about the first two weeks, example was going from 100% overnight to 75% the next morning, then it settled down to using just 2 or 3% overnight and similarly using not much playing games etc through the day.
    About 6 weeks ago the 100% - 75% overnight nonsense has returned and it's been like that for 6 weeks, it's just chewing through the battery and I don't even use it much at all.
    As a contrast, my near 4 year old Nexus 4, on the exact same plan with the exact same carrier loses a fraction of the battery in the same time. My Edge 7 was down to 40% now from a full charge last night (about 16 hours), I haven't so much as sent a text from it in that time or browsed or played games, no screen time except for checking the time, while my Nexus 4 is 78%.
    The Edge 7 is supposed to have fancy battery saving features, (app power save is switched on) a much bigger battery holding much more charge yet it's burning through it faster than an ancient Nexus 4. That's not progress imo.
    On the Edge 7, Cell Standby is always the top power user with about 40 odd %, on the Nexus, mobile standby is 1%.
    08-02-2016 08:28 AM
  3. Golfdriver97's Avatar
    Can you guys post screenshots of the battery stats?
    08-02-2016 08:30 AM
  4. Sean Fanelli's Avatar
    Its slowinf down a bit as the say goes on, but id expect more than 7 hrs on a 3600 mah battery
    I could very well still be in new shiny toy mode, i am using it quite a bit
    08-02-2016 09:00 AM
  5. PJRed2008's Avatar
    Unless I'm playing on the internet a lot, I get two to three days on my 7e, and still have battery left. The Play Store and a couple other apps have gone nuts occasionally and really pull the battery down, but a reboot has fixed those times. If you're seeing a large battery drain chances are you have an app that is doing it. Also, if you have excessive push notifications from social networks that will do the same thing. Install GSAM and track your usage for awhile. There are also may threads here about this same issue that might be helpful.
    08-02-2016 11:27 AM
  6. Doc Marten's Avatar
    I'll take a screenshot tomorrow, I'll charge both phones late at night and check them in the morning. What's the best way to upload the pics to here?
    08-03-2016 01:00 PM
  7. Doc Marten's Avatar
    That's it's use sitting by my bed over night.
    The Nexus 4, I can't find where the images are stored. It uses 1% for Mobile Standby in the same time.and Google Play Services is the top battery user. For effs sake, the images aren't working.
    Both phones are on the same individual contract with the same carrier. I've had the Nexus since it's release nearly 4 years ago.
    08-04-2016 07:31 AM
  8. Doc Marten's Avatar
    08-04-2016 07:34 AM
  9. Doc Marten's Avatar
    08-04-2016 07:35 AM
  10. Doc Marten's Avatar
    The Nexus 4 is still on 52%. The S7 Edge is down to 38% having had to be charged to 96% after going down to 50%. Similar usage between the two phones.
    So the S7 Edge went from 100% to 50%, charged back up to 96% now it's down to 38%.
    The Nexus 4 is still on the original charge when I did both phones.
    Something is seriously amiss when the phone with the battery saving features and a battery that's much bigger and newer by 4 years is getting comprehensively owned in the battery stakes.
    08-06-2016 02:57 PM
  11. Doc Marten's Avatar
    S7 Edge was on 7% this morning so I've had to charge it fully again. The Nexus 4 is still on 38%.
    S7 (as with Nexus 4) has had the initial charge to 100% and now has had to be charged fully twice. Nexus 4 is still on initial charge.
    So in the time the S7 Edge has gone from 100% > 50% > 96% > 7% > 100% the Nexus 4 has gone from 100% > 38%. The usage of each phone has been broadly similar.
    08-07-2016 08:43 AM
  12. Rumblee1's Avatar
    I've got to say I'm getting tremendous battery life. It's the first smartphone I've ever owned, that i have no worries about making it through the whole day. As an added measure, i am running greenify.
    08-07-2016 08:53 AM
  13. Doc Marten's Avatar
    I had horrible drain in the first couple of weeks then it performed like a champ for about 6 weeks and now it's back to what it was like in the first couple of weeks. I have no idea why except cellstandby takes number 1 spot.
    08-07-2016 09:34 AM
  14. GoAwaySheep's Avatar
    Mine is getting great battery life
    08-07-2016 04:39 PM
  15. Dukins's Avatar
    Mine is finally getting great battery life. After exhaustive efforts, I finally found the culprit for me. GasBuddy completely drains your battery even when not in use. Bottom line check your apps.
    08-08-2016 06:19 AM
  16. Doc Marten's Avatar
    OK, final summary. In the time it's taken a 4 year old Nexus 4 to go from 100% to 1% the S7 Edge, which is on the same deal with the same carrier, has done this battery wise -
    S7 Edge -
    100% > 50% > 96% > 7% > 100% > 8%
    Nexus 4 -
    100% > 1%
    The only usage the S7 Edge had in that time was sending and receiving about 8 texts. It had zero screen time outside of occasionally checking the time.
    If an app was causing this surely it would show up in the battery used list. CellStandby is always the top user.
    08-09-2016 07:29 AM
  17. jelliebean82's Avatar
    My S7E and also my husbands has horrible battery drain. I am getting very frustrated. In 6 hours I'm down to 32%...that's just basic checking FB, email etc
    08-09-2016 05:40 PM
  18. thecomicbookandme's Avatar
    Doc, something is definitely wrong. You should be getting much more battery life. Any reason why your cell standby is so high? Mine typically reads around 7%.
    Yea! Heavy And A Bottle Of Bread
    08-09-2016 06:34 PM
  19. xXxMVPete's Avatar
    How did you figure out that GasBuddy was draining your battery? Did you uninstall it or change a setting within the app?
    08-09-2016 08:30 PM
  20. kjung7's Avatar
    It looks like you have weak signal. Constant search for signal will drain your battery quickly. Also your Google play services percentage is pretty high. Mine hovers around 7%
    08-09-2016 08:56 PM
  21. Dukins's Avatar
    I ran test to see what was causing waklocks. The app never sleeps. Once I removed it, my battery has been top notch. I love this phone now. Also go look in the reviews for the app in the play store. Youll see others are saying the same thing.
    08-10-2016 06:54 AM
  22. Doc Marten's Avatar
    Been on live chat with Samsung support and they advised me to try a couple of things. I'd already cleaned the cache which made no difference then they suggested putting the phone in safe mode for 24 hours and see if the battery drain was the same or not. The battery drained the same amount so it's not an app I've added. So they're going to pick the phone up tomorrow and have one of their engineers take a look at it. I can't fault them for their speed of service and hope I get the phone back running the way it was after I'd had it about a week. It was just going through 3% over night then.
    08-10-2016 11:15 AM
  23. Doc Marten's Avatar
    If I only had this phone then perhaps that would be the issue however I have my near 4 year old Nexus 4 and it's on the exact same deal with the same carrier here in the UK, EE. They both sit on the same desk in my house and by my bed at night. When the S7 Edge has to go through this (100% battery > 50% > 96% > 7% > 100% > 8%) amount of charging in the same time the Nexus 4 goes from 100% - 1%, something is surely amiss.
    Newer device, bigger battery, power saving features etc, it should be tanking the Nexus and the point is, it used to!
    08-10-2016 11:20 AM
  1. What Battery Case will you be getting for your Note 7?
    By Dude2 in forum Samsung Galaxy Note 7 Cases & Accessories
    Last Post: 08-07-2016, 07:27 PM
  2. Trouble Charging & Fast Battery Drain-Android Tablet
    Last Post: 08-02-2016, 12:13 AM
  3. Replies: 1
    Last Post: 08-01-2016, 02:49 PM
  4. Is my battery life good?
    By Roflmahwaffle in forum Samsung Galaxy S7
    Last Post: 08-01-2016, 06:23 AM
  5. Why is my new LG G4 battery life draining so fast?
    Last Post: 08-01-2016, 03:12 AM
