Rearranging quick links in swipe down menu?
JM22508
Active member
May 13, 2010
37
I've tried to figure this out on my own, without success, so maybe it's not possible?
I came from the LG G4 which allowed you to edit the selection of quick links at the top of the swipe down. You could remove those you don't use and reorder the links. Is this possible on the S7 Edge?
cwbcpa
Trusted Member
Mar 21, 2011
1,378
Yes. Pull down twice and there will be an edit button on the top. Click that and you can arrange and add and remove as needed.
asha_kanta_sharma
