1. RocketFoot's Avatar
    I dabble in graphic design and I would like to make a few wallpapers for my S7E...what is the best resolution to use? I have seen people making them in native res of 2560 x 1440 but I also see some made at 2560 x 2880. I am guessing that the latter would be better for those that use features like Nova's scrolling wallpaper.
    08-03-2016 07:25 AM
  2. nahoku's Avatar
    The only "best" size is the one you want to make. If you want it to encompass the entire screen, then size it to your screen resolution (or multiples thereof). It's all up to you, really.
    08-04-2016 12:28 AM
  1. New to Moto 360 2nd Gen.
    By Preach2k in forum Moto 360 (2015)
    Last Post: 08-20-2016, 04:56 AM
  2. Galaxy S7 - Gallery crashes after a day's use + SD error
    Last Post: 08-04-2016, 12:25 PM
  3. How to add LTE Band 3 1800Mhz support on Verizon Smartphones
    Last Post: 08-03-2016, 09:14 AM
  4. Why are my txt messages going to fb messager
    Last Post: 08-03-2016, 06:58 AM
