1. tshirttan408's Avatar
    Hi Guys,
    So I've recently bought one of those cases that double as a wallet as well. I've done a quick search because what I though would be really handy is to have an app that automatically locks my phone when covered, and have downloaded an app call pocket lock. The only problem is (and I had this with a double tap the screen lock app) is that when I unlock I have to enter the pin. Does anyone know if there are any work arounds for this?
    Thanks in advance.
    08-04-2016 05:20 AM
  2. B. Diddy's Avatar
    There should be a setting on the phone to adjust how long to wait after the screen is off before the screenlock becomes activated--you could set that to a short time (like 5 seconds) or Immediately. Then you could use Smart Lock to make sure the phone is unlocked when you open the case, as long as it's connected via Bluetooth to a Trusted Device (like a Bluetooth headset), or if you're using On-body Detection (On-body detection explained | Android Central).
    08-06-2016 01:46 AM
  1. Download apps without Google play store
    Last Post: 08-04-2016, 09:42 AM
  2. What apps I don't need on my Galaxy Core
    Last Post: 08-04-2016, 04:40 AM
  3. Why cant i find the quick memo i saved
    Last Post: 08-04-2016, 04:38 AM
  4. My LG G3 randomly turned off and won't turn back on?
    Last Post: 08-04-2016, 04:37 AM
  5. Replies: 1
    Last Post: 08-04-2016, 04:33 AM
